5 Channel Amps, need you opinion
I need to buy a 5ch amp, any good deals out there? Anyone have a recomendation for a Joe6pack budget? Thanks
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
Post edited by hoosier21 on
Considered the Marantz monoblocks?
Cheers,
Russ
The Rotel is in my sites, if you see one for 300.00 man I want it, I ususally see them around 500.00+
Of course that is clean, Rotel power, and with the Nad gear you have owned, we don't even need to discuss headroom...
Cheers,
Russ
BDT
A couple are floating on Audiogon. Did you get any bites on your 1c's yet?
Cheers,
Russ
SDA 1C's - Got a good bite, no cash yet.
Cheers,
Russ
Shipping speakers is a major pain, I made a large plywood box to ship a pair of SDA 2.3's
Thanks again,
Jer
Well this joe6pak bought a dennon 3802 last november. It was $900 +.
joe
