Polk L200
VR3
VR3 Posts: 29,731
edited August 2021 in DIY, Mods & Tweaks
Walnut veneer is very classy, love the matte black baffle. I do think a round tweeter faceplate like the reserve would look better.
The midrange circuit has two iron core inductors in series to the mid driver. Ceramic resistors. Just changing these items would have a positive impact on the sound for sure.
A good portion of the parts makes up some series notch filters, I would say unless you were going all out, just updating the resistors and the electrolytic cap being used is OK in a target mod.
Definitely one of Polks more complex crossovers
«134
  • rooftop59
    rooftop59 Posts: 8,120
    But how do they sound man?!?
    Game Room 5.1.4:
    Bedroom 2.1
    VR3 Posts: 29,731
    Fairly neutral with alot of bass. Was surprised by the lack of staging outside of the speakers but they are new so that should improve a bit as they break in 😁
  • CottageChz
    CottageChz Posts: 424
    Are you gonna mod them after you have a chance to listen to the stock version for a while?
    VR3 Posts: 29,731
    These are not mine but I do believe we will mod them!
  • smglbrth
    smglbrth Posts: 1,504
    Did you just pry the ring off to get the driver out?
    VR3 Posts: 29,731
    The ring attaches like a grill with pegs
  • CottageChz
    VR3 wrote: »
    Nice! I have never heard any VR3 mods but still hope to someday, so I’m glad to see the mods continuing!
    Clipdat Posts: 13,104
    edited August 2021
    What kind of a fool would have you upgrade a speaker's crossovers before ever having heard them in stock form?
    (It was me. I drop shipped them to Trey from A4L - $999 refurb pair!)
    Sand cast resistors be gone!
  • maxward
    maxward Posts: 1,742
    I pity da fool!
    VR3 Posts: 29,731
    Gonna be amazeeeee
    @VR3 post up the final parts list when you get a chance!
    pitdogg2 Posts: 27,883
    VR3 Posts: 29,731
    I'm not everything will fit, duelund caps are bigger than the enclosure.
    Have a 10x10 storage shed to pair them with
    msg Posts: 10,640
    VR#2
    Clipdat wrote: »
    Can you make the crossover's outboard storage shed look like this?
    mhardy6647 Posts: 35,555
    So -- I'm just curious -- if/when all y'all replace the iron core inductors with air core, how close do the replacement inductors match the DCR of the originals? Seems like there's quite a bit more copper wire (length) in the air core coils compared to the iron (or permalloy or whatever) cored originals, so - presumably - it's essential to use air coil inductors with really (really!) large-gauge wire to keep the DCR, umm, competitive? :)
    Speaking of air core inductors -- I've developed a taste for these rascals. I was able to convince myself that I heard a difference (to wit, an improvement) when I swapped them in (yes, using clip leads, of course -- I am me, after all...) for some normal perfect-lay wound wire air core inductors in the Frankenaltecs.
    The Goertz foil coils aren't cheap, but they're also not frighteningly expensive... and I do like their purposeful appearance :) They look like they mean business.
    Perhaps kinda big for L200s, tho'.
    VR3 Posts: 29,731
    I was able to find an exact dcr match from mundorf. If I recall it is 12 or 14 awg, can't recall off hand.
    VR3 Posts: 29,731
    Foil inductors do have a particular sound, I like them but sometimes hard to find dcr matches in that variety
    Tony M Posts: 12,001
    The "wood-winds" would sound pretty realistic.
    VR3 Posts: 29,731
    Copper, only 2 of the four iron cores on the board... Would be an extremely large crossover with all air core inductors... Definitely would have to go external!
    Dats alotta coppa
  • ALL212
    ALL212 Posts: 1,681
    @VR3
    How’d you get the rings off? Maybe I should try a smaller crow bar?? :o
    I’ve got the L100’s and will put a pic of those parts in a post but I don’t want to make a mess either.
    Aaron
    Enabler Extraordinaire
    VR3 Posts: 29,731
    They pull off like a grill
  • ALL212
    ALL212 Posts: 1,681
    Ahhh… got it!
    Thank you
    Aaron
  • ALL212
    ALL212 Posts: 1,681
    You a… you a could cook up a couple more of those boards? Just the boards…
    Looks like I’ll be working on upgrades this winter.
    Aaron
    VR3 Posts: 29,731
    Sure, just have to hit print 😝
