AQ USB Cable
Clipdat
Audioquest Carbon USB cable - 1.5m - $100 shipped
https://www.amazon.com/AudioQuest-Carbon-Cable-Type-1-5m/dp/B0041EDIIW
I know a guy that might trade some ELAC bookies for that cable Drew.
Buy them both FFS.
Bump. Nobody wants to upgrade their USB cable?
Also open to trades for other ($200-ish) 1.5m USB cables. -
Are these sonically better than my $15 Monster Cable USB's? I mean personally I think higher end cables are just psychological. Well unless you smoke weed. I'd give it a try but I need 2.5m. GLWTS!Gustard X26 Pro DAC
Believe it or not there's audible differences between USB cables. It sure would be a hell of a lot easier if they all sounded the same.
I explored this a bit here: https://forum.polkaudio.com/discussion/184270/three-way-usb-cable-shootout -
I would like to have you review a Wireworld cable sometime. Unfortunately when I looked at them they go from a $140 cable to a $900 cable. Of course I want the $900 one. There are just so few reviews of Wireworld stuff other than the couple of guys here that use them.Gustard X26 Pro DAC
Like it or not, cables matter. Personally I feel cables, and power, are the foundation for a stereo. However, since I don’t use USB cables I can’t comment on any sonic benefits from them.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
...However, since I don’t use USB cables I can’t comment on any sonic benefits from them.
Gee, thanks
Price drop $80 shipped.
I'll give those a try, Drew. PM sent.
I wanted to jump on it as I'm a self admitted AQ fan Boy. But with the equipment I have I could not use that cable. What's the main use for this type of cable? Connect what to what?
PC to DAC or streamer to DAC.
Let me know what you think of them as you have similar cabling.I'll give those a try, Drew. PM sent.
So my internet was down for a while yesterday so my CA 851N wouldn't stream. Had to drag out an old Panasonic DVD player to use as a transport and used an optical cable to the 851 to play some tunes with CD's. YUK! I know they say USB is better but this was crazy. I was playing some tune when the internet came back on and immediately replayed it via Tidal master off my Toshiba laptop with the skullcandy sound card using a cheap USB cable and immediately realized if the internet goes out again I'm just going to go mow the lawn or something.
@ audioluvr i dare say it might be the "old dvd player" and optical connection.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
That's possible. Just hard to believe that's what I was using before I discovered Club Polk. You guys are awesome! Or Horrible enablers depending how you look at it.Gustard X26 Pro DAC
I'll let you know how it sounds. Going to connect my Mini to an external ProJect DAC that I use with a CD spinner. Been using the Mini's onboard DAC until now. Eventual plan is to get a better DAC and more silver in the USB. Baby steps. But, the convenience of streaming is addictive.
This has been sold.
