AQ USB Cable
Audioquest Carbon USB cable - 1.5m - $100 shipped
https://www.amazon.com/AudioQuest-Carbon-Cable-Type-1-5m/dp/B0041EDIIW
  • CH46E
    CH46E Posts: 3,595
    Clipdat wrote: »
    I know a guy that might trade some ELAC bookies for that cable Drew.
    :p
    Clipdat Posts: 13,095
    Buy them both FFS.
    Bump. Nobody wants to upgrade their USB cable?
    Also open to trades for other ($200-ish) 1.5m USB cables.
    audioluvr Posts: 5,914
    Are these sonically better than my $15 Monster Cable USB's? I mean personally I think higher end cables are just psychological. Well unless you smoke weed. I'd give it a try but I need 2.5m. GLWTS!
    Believe it or not there's audible differences between USB cables. It sure would be a hell of a lot easier if they all sounded the same.
    I explored this a bit here: https://forum.polkaudio.com/discussion/184270/three-way-usb-cable-shootout
    I would like to have you review a Wireworld cable sometime. Unfortunately when I looked at them they go from a $140 cable to a $900 cable. Of course I want the $900 one. There are just so few reviews of Wireworld stuff other than the couple of guys here that use them.
  • BlueFox
    BlueFox Posts: 15,251
    Like it or not, cables matter. Personally I feel cables, and power, are the foundation for a stereo. However, since I don’t use USB cables I can’t comment on any sonic benefits from them.
    BlueFox wrote: »
    ...However, since I don’t use USB cables I can’t comment on any sonic benefits from them.
    Gee, thanks :D
    Price drop $80 shipped.
  • Dr_Wu
    Dr_Wu Posts: 356
    I'll give those a try, Drew. PM sent.
  • CH46E
    CH46E Posts: 3,595
    I wanted to jump on it as I'm a self admitted AQ fan Boy. But with the equipment I have I could not use that cable. What's the main use for this type of cable? Connect what to what?
    PC to DAC or streamer to DAC.
    Dr_Wu wrote: »
    Let me know what you think of them as you have similar cabling.
    So my internet was down for a while yesterday so my CA 851N wouldn't stream. Had to drag out an old Panasonic DVD player to use as a transport and used an optical cable to the 851 to play some tunes with CD's. YUK! I know they say USB is better but this was crazy. I was playing some tune when the internet came back on and immediately replayed it via Tidal master off my Toshiba laptop with the skullcandy sound card using a cheap USB cable and immediately realized if the internet goes out again I'm just going to go mow the lawn or something.
  • marvda1
    marvda1 Posts: 4,943
    edited August 2021
    @ audioluvr i dare say it might be the "old dvd player" and optical connection.
    Puritan PSM156
    That's possible. Just hard to believe that's what I was using before I discovered Club Polk. You guys are awesome! Or Horrible enablers depending how you look at it.
  • Dr_Wu
    Dr_Wu Posts: 356
    I'll let you know how it sounds. Going to connect my Mini to an external ProJect DAC that I use with a CD spinner. Been using the Mini's onboard DAC until now. Eventual plan is to get a better DAC and more silver in the USB. Baby steps. But, the convenience of streaming is addictive.
    This has been sold.
