WHY CANT I CONNECT MY HEADPHONES TO MY POLK SOUNDBAR USING BLUETOOTH?
I did CONNECT my headset to my Magfi Mini Sound bar but I can't hear anything?
    txcoastal1 Posts: 13,499
    The soundbar is not the source of the music. Bluetooth to your music source
    msg Posts: 10,450
    See if you can hear anything in lowercase. Might have blown the headset.
    audioluvr Posts: 5,867
    How do you know what he may have blown???
  • coolsax
    coolsax Posts: 1,826
    on the off chance you're asking a serious question. the Magnify mini is a bluetooth receiver which means it can receive a bluetooth signal to play sound, just like your headphones. It is not a transmitter, so it cannot transmit a bluetooth signal to your headphones, so if you're trying to transmit to your headphones by a device connected to the Mini (such as the TV), its not going to work. If the device that's playing the sound is also bluetooth then you need to connect that device to your headphones. If that device is hardwired to the Mini, then you will need a bluetooth transmitter to listen to that device on your headphones.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
