WHY CANT I CONNECT MY HEADPHONES TO MY POLK SOUNDBAR USING BLUETOOTH?
Bluesrains
in Headphones
I did CONNECT my headset to my Magfi Mini Sound bar but I can't hear anything?
The soundbar is not the source of the music. Bluetooth to your music source2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
See if you can hear anything in lowercase. Might have blown the headset.I disabled signatures.
How do you know what he may have blown???Gustard X26 Pro DAC
on the off chance you're asking a serious question. the Magnify mini is a bluetooth receiver which means it can receive a bluetooth signal to play sound, just like your headphones. It is not a transmitter, so it cannot transmit a bluetooth signal to your headphones, so if you're trying to transmit to your headphones by a device connected to the Mini (such as the TV), its not going to work. If the device that's playing the sound is also bluetooth then you need to connect that device to your headphones. If that device is hardwired to the Mini, then you will need a bluetooth transmitter to listen to that device on your headphones.Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22
