How far apart you guys running your sda
VR3
VR3 Posts: 29,444
Been a long time since I've had a pair in the house, running the 1.2tl now. I started at 9 ft apart and much prefer 7ft apart, very curious how far apart you guys are running
  • Emlyn
    Emlyn Posts: 4,727
    When I had SDAs usually a little closer together than the distance from the center point between the speakers to the ears. Ten feet away would be about six to eight feet apart from the inside edges.
    pitdogg2 Posts: 27,069
    My 2.3tl are at 7' also
    VR3 Posts: 29,444
    Gotcha, sounds great at 7 ft. I need to work on getting the spikes installed next
    F1nut Posts: 51,794
    6 feet apart inside to inside edge, sitting 9 feet back.
  • gidrah
    gidrah Posts: 3,049
    I just picked up my first pair of SDAs and look forward to trying different locations.
    Make it Funky! :)
    VR3 Posts: 29,444
    Just installed spikes and leveled, will look to listen again tomorrow time willing!
    Tony M Posts: 11,625
    8 1/2' center to center.
    Being able to place my couch at the triangular distance point, I can now enjoy the magic again. B)
  • jonicont
    jonicont Posts: 281
    8’ tweeter to tweeter, 8’ tweeter to ear
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • aprazer402
    aprazer402 Posts: 3,389
    edited June 2021
    2.3's are 8 feet apart measured from center of each speaker. Seated 12 feet away from front of speakers. Probably a little too far back, but best place for the furniture. Room is approx. 16' X 17' and carpeted.
    SDA 1C's are in another more rectangular large room along a long wall 11 feet apart with listening location about 10 feet back. This room has hardwood flooring with a small area rug. Sounds good also.
    Post edited by aprazer402 on
  • motorstereo
    motorstereo Posts: 2,345
    1.2tl's are 6' apart tweeter to tweeter. I'd love to spread them out more but keeping them at least 3' from the sidewalls is important. Listening distance varies from 6-9' back.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    My 1.2tls are 12' apart, center to center, and the center of each is 12' from my listening position. Yes, an equilateral triangle!
  • xsmi
    xsmi Posts: 1,801
    SDA-SRS's 6 feet apart 9 feet away.
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • muncybob
    muncybob Posts: 3,243
    my 2Bs are 7' 6" tweeter to tweeter, chair is apprx 10' from soundstage center point.
    Yep, my name really is Bob.
  • TroyD
    TroyD Posts: 13,124
    I always found that putting them closer together was a good thing.....the farther apart they are, I find the mid's and upper bass get a bit muddier. May just be me though...
    VR3 Posts: 29,444
    Agreed, the father apart the more off axis you are from the tweeters and mids since you don't angle them in
  • jbail2011
    jbail2011 Posts: 102
    My 2.3 TL are sounding awesome 7 feet apart and 9 feet away.
    Polk Audio SDA SRS 2.3 TL
    Polk Audio SDA 2B TL mod
    Carver M 1.0 MK2 Opt 2 x2
    Carver CT Seven Preamp
    Bluesound Node 2i
  • Inscrutabl0915
    Inscrutabl0915 Posts: 47
    edited June 2021
    Using this rack they are 5’8” clear between cabinets (and 5” to back wall), but only give me 19” clear to sidewalls. Will try moving out rack and reduce to 5’-0” giving me 23” to sidewalls. Still not what I’d like and used to have in a bigger room, but best I can do right now.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    6 feet-7-3/4 inches apart, inside edge to inside edge. My head is 12 feet back from the center point of the speaker front plane.
  • honestaquarian
    honestaquarian Posts: 3,260
    My 3.1's that you did the crossovers on are about six feet apart from inside edge to inside edge. That way I can have them three feet from the sidewalls measured from the outside edge.
