How far apart you guys running your sda
VR3
Been a long time since I've had a pair in the house, running the 1.2tl now. I started at 9 ft apart and much prefer 7ft apart, very curious how far apart you guys are running
When I had SDAs usually a little closer together than the distance from the center point between the speakers to the ears. Ten feet away would be about six to eight feet apart from the inside edges.
My 2.3tl are at 7' also
Gotcha, sounds great at 7 ft. I need to work on getting the spikes installed next- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
6 feet apart inside to inside edge, sitting 9 feet back.Political Correctness'.........defined
President of Club Polk -
I just picked up my first pair of SDAs and look forward to trying different locations.
Make it Funky!
Just installed spikes and leveled, will look to listen again tomorrow time willing!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
8 1/2' center to center.
Being able to place my couch at the triangular distance point, I can now enjoy the magic again.
8’ tweeter to tweeter, 8’ tweeter to earDynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
2.3's are 8 feet apart measured from center of each speaker. Seated 12 feet away from front of speakers. Probably a little too far back, but best place for the furniture. Room is approx. 16' X 17' and carpeted.
SDA 1C's are in another more rectangular large room along a long wall 11 feet apart with listening location about 10 feet back. This room has hardwood flooring with a small area rug. Sounds good also.Post edited by aprazer402 on -
1.2tl's are 6' apart tweeter to tweeter. I'd love to spread them out more but keeping them at least 3' from the sidewalls is important. Listening distance varies from 6-9' back.
My 1.2tls are 12' apart, center to center, and the center of each is 12' from my listening position. Yes, an equilateral triangle!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
SDA-SRS's 6 feet apart 9 feet away.2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
my 2Bs are 7' 6" tweeter to tweeter, chair is apprx 10' from soundstage center point.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
I always found that putting them closer together was a good thing.....the farther apart they are, I find the mid's and upper bass get a bit muddier. May just be me though...I plan for the future. - F1Nut
Agreed, the father apart the more off axis you are from the tweeters and mids since you don't angle them in- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
My 2.3 TL are sounding awesome 7 feet apart and 9 feet away.Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i -
Using this rack they are 5’8” clear between cabinets (and 5” to back wall), but only give me 19” clear to sidewalls. Will try moving out rack and reduce to 5’-0” giving me 23” to sidewalls. Still not what I’d like and used to have in a bigger room, but best I can do right now.
6 feet-7-3/4 inches apart, inside edge to inside edge. My head is 12 feet back from the center point of the speaker front plane.Proud and loyal citizen of the Digital Domain and Solid State Country!
My 3.1's that you did the crossovers on are about six feet apart from inside edge to inside edge. That way I can have them three feet from the sidewalls measured from the outside edge.
