Bad Crossover? RTi10
Got a deal on a pair of these and some other speakers. But with my recent string of luck, one of the tweeters will not work (I've switched it out and still a no-go). The crossover doesn't look bad to me. Any idea/s? Thanks in advance for any help!
Jumper plates missing?Political Correctness'.........defined
President of Club Polk -
No, sir, they are there and very secure. And have banana plugs connected on the top row.
Look for bad solder connections on the XO circuit boards.Stan
Main 2ch:
HT:
Other stuff:
Would the IN2- be considered a bad solder connection?
The solder pad is on the green side and it appears to have a nice blob of solder on it, although it's not as shiny as one may like. Hit it with a solder iron.Political Correctness'.........defined
Do you have a VOM?Political Correctness'.........defined
First thing you want to look at ...see pic 2 in the thread link posted below. The white sandcast resistor is one of the first things that seem to blow in the RTiA9's. The RTi10 is the A9's predecessor
https://forum.polkaudio.com/discussion/166579/free-polk-rti10-crossover-essentially-brand-new-polk-sent-wrong-one-via-a7-warranty-replacement
Thank you all for the replies! When I pulled out the crossover earlier for the other pictures I removed some "stuff" from contacts common to the terminals. It now works! Blows my mind that that was all it needed.
Huh?Political Correctness'.........defined
There was some sort of residue/buildup on these perfectly circled areas.
Interesting!Political Correctness'.........defined
Very! Don't know what exactly it was, but it did flake off.
So it must have been conductive and causing a short. I wonder where that crap came from?
Could you have moved something that was not making good contact before (back to the bad solder joint idea)?Stan
Main 2ch:
HT:
Other stuff:
