Bad Crossover? RTi10
alecd70
alecd70 Posts: 13
Got a deal on a pair of these and some other speakers. But with my recent string of luck, one of the tweeters will not work (I've switched it out and still a no-go). The crossover doesn't look bad to me. Any idea/s? Thanks in advance for any help!a0gi6pyrfxbc.jpg
    F1nut Posts: 51,962
    edited May 2021
    Jumper plates missing?
  • alecd70
    alecd70 Posts: 13
    No, sir, they are there and very secure. And have banana plugs connected on the top row.
  • skrol
    skrol Posts: 3,460
    Look for bad solder connections on the XO circuit boards.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • alecd70
    alecd70 Posts: 13
    edited May 2021
    F1nut Posts: 51,962
    edited May 2021
    The solder pad is on the green side and it appears to have a nice blob of solder on it, although it's not as shiny as one may like. Hit it with a solder iron.
    F1nut Posts: 51,962
    Do you have a VOM?
    txcoastal1 Posts: 13,519
    First thing you want to look at ...see pic 2 in the thread link posted below. The white sandcast resistor is one of the first things that seem to blow in the RTiA9's. The RTi10 is the A9's predecessor
    https://forum.polkaudio.com/discussion/166579/free-polk-rti10-crossover-essentially-brand-new-polk-sent-wrong-one-via-a7-warranty-replacement
  • alecd70
    alecd70 Posts: 13
    Thank you all for the replies! When I pulled out the crossover earlier for the other pictures I removed some "stuff" from contacts common to the terminals. It now works! Blows my mind that that was all it needed.
    F1nut Posts: 51,962
    Huh?
  • alecd70
    alecd70 Posts: 13
    There was some sort of residue/buildup on these perfectly circled areas.q72dziasj8vg.jpg
    F1nut Posts: 51,962
    Interesting!
  • alecd70
    alecd70 Posts: 13
    Very! Don't know what exactly it was, but it did flake off.
  • skrol
    skrol Posts: 3,460
    edited June 2021
    So it must have been conductive and causing a short. I wonder where that crap came from?
    Could you have moved something that was not making good contact before (back to the bad solder joint idea)?
    Stan
    Main 2ch:
    HT:
    Other stuff:
