PSW 10 operation
I am new to subwoofing and at a loss to understand what the switches and dials on the back of the speaker do. I understand the volume nob that’s it. The manual is strangely silent on this. What should I set these at for best performance ?
  • stevep
    stevep Posts: 360
    Volume - Adjusts the output loudness. (You know it)
    Low Pass - Adjusts the crossover point for the subwoofer. Frequencies below the setting are played.
    Power - Off, Auto (On when there is a signal), On
    Phase - 0 degrees, 180 degrees (adjusts the subwoofer output like changing the wire polarity on a speaker does)
    Line In - Right and Left Pre-Amp level inputs. (Use a Y adapter for a LFE signal)
    Speaker Level Output
    Speaker Level Input - These are strapped together In to Out and feed the sub from the speaker level voltages rather than the RCA Line in level voltage on connector above.
    How do you have it hooked up ? By the subwoofer out connection on the back of the receiver, or by speaker wires ?
