MW6511 Replacement
jbail2011
jbail2011 Posts: 102
I am down to my last vintage mw6511 and am looking for a replacement for my SDA 2b tl speakers. I read in a post that RD 6110-1 were a good choice however Polk CS says they are not available. Mid West Speaker recommends MW-6502-4. Do you guys agree or have a better recommendation?
Thank you in advance.
Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i
    F1nut Posts: 51,954
    How/why are you damaging the mid-drivers?
  • jbail2011
    edited April 2021
    I am not sure. This was one of a pair of original me 6511 drivers I bought from another polkie. I found it wasn’t working the other day. I replaced it and now back up and running.
    Bluesound Node 2i
    F1nut Posts: 51,954
    jbail2011 wrote: »
    Had you glued the magnets?
  • jbail2011
    jbail2011 wrote: »
    As a matter of fact they are not glued...
    Bluesound Node 2i
  • jbail2011
    Bluesound Node 2i
  • michaeljhsda2
    michaeljhsda2 Posts: 2,202
    Looks like the wire is missing from the left tab. Dynamat should never be placed over that area...wow...bad idea whoever did that...ruined the MW.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jbail2011
    Noted. Thank you
    Bluesound Node 2i
    F1nut Posts: 51,954
    jbail2011 wrote: »
    jbail2011 wrote: »
    Glue up the ones that still work. You can see if member lawdogg will accept your damaged one in exchange for one he has repaired.
    The one Midwest sells is a one model fits all, it's not an exact match. If course, you can shop eBay for an exact match.
  • jbail2011
    jbail2011 wrote: »
    jbail2011 wrote: »
    Thank you.
    Bluesound Node 2i
