Pioneer SC-27 paired with Reserve line?
GiantPanda
in Speakers
How well will my Pioneer SC-27 pair with Reserve line speakers?
Looking to update my Front channel speakers from ADS 780’s to R-200 (or L200’s if money were no object)
Thoughts?
Thoughts?
My rear channel uses S15 bookshelf’s
Center channel is CS-10
You know you have an hour to edit correct? 😁
It should work well. The pioneer class D amps are pretty stellar. -
I used to have an SC27. The Ice amp in it was darn good. You should be fine.
Yep. The SC27 was a $2K receiver when it came out about 11 to 12 years ago. The amp will output more than 200 watts to a 4 ohm load in stereo mode at low distortion. About half that for all channels driven at max continuously which nobody does anyway. This is why I called these Pioneer receivers with high quality class D amps game changers for home theater use when they started. I still have two of them that are more recent models.
https://www.soundandvision.com/content/pioneer-elite-sc-27-av-receiver-ht-labs-measuresPost edited by Emlyn on -
Thank you all for the feedback
GiantPanda wrote: »Center channel is CS-10
You really want the front 3 speakers to be timbre matched for the best results.
I agree with the others, your Pioneer AVR will have no problems driving the Reserve or Legend series speakers.Political Correctness'.........defined
