Anti diffraction rings (for tweeters)
  • JayCee
    B)
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    Here is 2.3TL overlay
  • What about the 3.1TL's?
    Yes sir, I just need to know the total height including the diffraction strip that came from the factory above it
  • Total height of the entire speaker or just the tweeter?
    I would need to know the measurement from the bottom of the tweeter to the top of that strip in the photo
  • Is anyone else having trouble tonight with the forum?
    I’m trying to upload a pic and it won’t let me do it.
    Keeps timing out.
    Anyway 4 5/8” inches
  • JayCee
    Keeps timing out.
    Yes, tried to load a few pics and get something like a "failed to upload" error. Tried 2 different browsers and no luck.
    edited March 2021
    Yes Carlton I have been fighting that all night. Keeps saying something about vanilla servers. Something is amiss.
    I will draw up a mock up for the 3.1 tonight and update.
    I was having issues as well with pictures, I used url links from old posted photos in half the pics
    edited March 2021
    Will the AD rings negate the need for that plastic strip across top of tweeter?
    Really cool, yet functional upgrade either way.
    It should negate the need for the strip but also wouldn't hurt to leave it either
    In that case, I'll take a pair for the 8TLs when they are ready. Thanks for making these available.
    the dark line up top will be a route out to give it a bend
  • So the material would go onto the tweeter faceplate AND the diffraction strip above it?
    Yes
    I could include two pairs, one without and one with four you to compare as well.
    The way that strip is designed it looks like it would interact with the midrange driver as well, so would need to test both to come up with the best solution
  • Where would the velcro dots be mounte, in between the top and bottom of the RDO198's, using two dots or on each mounting screw using 4 dots? No question is to dumb right? I might pick up a pair for 2.3tls.
    I would probably do the top two mounting screws and then two dots below the tweeter, leaving the bottom two mounting screws floating. (for a single tweeter)
  • Trey I’m interested in a pair for my 2.3tl’s. Let me know when you can have them available.
    I have more material arriving today, once I have everything cut, let me see if I need to order more to make for the 2.3
    I used the little doughnut rings on mine today for about a hour and I couldn't believe the difference, totally forgot how much improvement these things bring
  • stevep
    Those tweeters seriously need washers on the back side of the mounting screws.
  • JayCee
    Aw, hell. Add 3.1tl's to my order. Please PP me and I'll send more $.
    Inquiries not invoiced yet -
    @xschop RTA8TL (one pair with the tab and one without)
    @honestaquarian 3.1tl (one pair with the tab and one without)
    @JayCee 3.1tl (one pair with the tab and one without)
    @Drumingman (one pair 2.3)
    @gudnoyez (one pair 2.3?)
    @muncybob (2b)
    Not sure if I missed anyone else??
    2.3tl!
  • stevep wrote: »
    Larry’s rings are behind all of the drivers. Which is why you don’t see the regular Phillips screw there and instead you see the Allen screws. I did this during the big, giant dreadnought group buy of 2016. I also got Trey to do the crossovers. You can see the upgrades in my thread about it.
    On the 3.1tl, I'm including two sets so you guys can give me feedback, price includes both pairs
  • stevep
    stevep wrote: »
    The RDO tweeters need a washer under each mount point so you don't distort the bezel when you tighten them. I understand that those button head Allen bolts are also missing the countersink on the rear but that only makes the distortion of the bezel worse.
    However they're your speakers and this is a FS thread so I'll stop off topic posting.
  • VR3 wrote: »
    No washers on these either.
