Anti diffraction rings (for tweeters)
1235»
  • Gardenstater
    Gardenstater Posts: 4,991
    edited March 2021
    Here's another example. Looks like open cell foam. M&K K17 "Titanium" Speaker.
    https://hometheaterhifi.com/volume_9_2/mk-k-series-vk-sub-4-2002.html
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,927
    edited March 2021
    VR3 wrote: »
    I actually have a whole bunch of little doughnuts I cut in the waste. Half inch OD with a quarter in id
    Those may be and improvement over the factory dome backing pads on the Peerless silks and RD0 silks. I found a couple of them detached when I opened them up.
    The M&K tweeter looks like a sticky dome.😁
  • hytekrednek
    The little donuts felts are not scrap, they look like anti vibration pads, or isolation washers! Turn waste into $$
    I would like to get a set of these felt pads for my 2.3tl's please. Also, if you have some left, a dozen or 2 of the scrap felt donuts.
    I hate to cover up these beautiful billet tweeter plates, but if it results in better sound, then let it be.
    VR3 Posts: 29,763
    Have an updated design for the RD0198/194 (horizontal and vertical)
    treitz3 Posts: 20,367
    I meant to chime in earlier on but life kept getting in the way.
    Do NOT use Velcro to stick these onto your baffle. It defeats the purpose. While it may be better? Just do not do it. Get the 3M damage free hanging pads. This insures no space between the baffle and the diffuser.
    UPC 51131-85124
    VR3 Posts: 29,763
    Yes, that is technically the "hook" part of velcro, otherwise know as hook and loop.
    But definitely best way to go as it's easy to remove in future
  • gp4jesus
    gp4jesus Posts: 2,025
    edited October 2021
    Speakin’ ‘o chimin’ in…
    Trey: I’m very sorry for not posting MUCH sooner
    RTi A7 & CSi A6 WITH Trey’s diffraction pads. At the moment, held in place w/Velcro & the grill pegs.
    Enjoy! Tony
    *all connected w/Premiere ICs
    VR3 wrote: »
    CHIT! NO!. This is NOT what I was referring to. NO VELCRO. Just 3M sticky 2 sided stuff.
    Damned 3M UPC codes... NO velcro!
  • Sebas75
    Sebas75 Posts: 2
    edited March 2022
    VR3 wrote: »
    Hello VR3,
    I have a question. I made big speakers. but I made a mistake with the front face of my tw29DN tweeter (29 dome) .
    The tweeter are not flush with the baffle, in fact on the right side it is proud by about 5mm
    So for the aesthetic side and to limit the diffraction. I am looking for a square or ring of anti-diffraction foam 15 cm by 15 cm, not necessarily very thick. the star or circle center need not be close to the dome like the picture 1.
    kinda like in this photo.
    do you have something like this? if so at what price?
    I am French
    Cordially
    sebastian
  • Sebas75
    Sebas75 Posts: 2
    VR3 wrote: »
    Hello,
    do you think the 2.5" hole is big enough for the dome of the tw29dn?
    if so, I'll take the star-shaped one.
    for the width I see that the second is 5x5, I would rather need 6,5×6,5. but if it's complicated I would take 5x5.
    Sebastian
