New Thread: Diffraction Pads/Rings
VR3
VR3 Posts: 29,533
edited March 2021 in For Sale (FS) Classifieds
So my first thread kind of went crazy, sorry for making a different thread, but it seems to make sense.
So I can make any type of diffraction pad (within reason) so any dimension, shape, etc.
They are made of wool/felt and are laser cut/engraved.
They can be easily attached with velcro strips/dots.
Below are some examples.
Pricing examples are as follows, for a pair, with shipping.
1.2TL Pads, $37
2.3TL Pads, $29
Single tweeter $15
Diffraction ring $12
Minimus 7 Pads $22
Diffraction is what happens as the sound wave extends across the baffle and interacts with screws, grills, baffle edges, etc. An example of that is below -
Some examples -
  • pearsall001
    pearsall001 Posts: 5,325
    Interesting...I wonder if they would work with the KEF R3 Uni-Q driver.
    VR3 Posts: 29,533
    Would be fairly easy to do a simple ring that went around the woofer for sure. Alot of coax drivers have a felt/foam ring around the tweeter as well
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Here's a photo of the classic Spica TC50 designed by John Bau.
    VR3 Posts: 29,533
    Excellent, looks like he had those punched and the grills completed it. Great design
    @Clipdat that is what we will do with yours
    VR3 Posts: 29,533
    1.2tl
  • CH46E
    CH46E Posts: 3,595
    It would be awesome if you can make me some for the 2 front Infinity EMIT tweeters when you put my crossovers together. For a fee of course.
    VR3 Posts: 29,533
    Absolutely, I would just need a tweeter or really detailed measurements!
  • muncybob
    muncybob Posts: 3,262
    Would the SDA benefit from greater coverage like the Minimus?
    Yep, my name really is Bob.
    VR3 Posts: 29,533
    I do believe a ring around the midbass driver that fits between the surround and the basket edge would be beneficial.
  • Gardenstater
    Gardenstater Posts: 4,801
    I would like to try one of those too^^ I wonder which is the worst offender......the basket rim (which really sticks out in un-rabbeted vintage monitor baffles), or the right angle cabinet edges.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    VR3 Posts: 29,533
    Really the whole baffle and grill, plus the baskets would cause diffraction, the drivers themselves would cause some diffraction from other drovers. Very little was done to combat diffraction with the sda.
    I have some midbass drivers here, will see what I can draw up
  • Gardenstater
    My very early 7B's have a grill cover where the particle board frame is not even rounded over on the inside. That can't help. I have been listening for many months without them but now with all the mods making the speakers more transparent and even a bit bright and revealing sometimes, I thought I would try putting them back on. More mellow sound for sure, but those sharp inside corners got me thinkin'.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • TroyD
    TroyD Posts: 13,124
    Sid,
    Shut up and take my money!!
    AR did this type of thing with the AR9 series Acoustic Blanket...
    Well done, sir!
  • JayCee
    JayCee Posts: 1,509
    edited March 2021
    VR3 wrote: »
    I should just give you my PP account and let you tell me when I have money for things other than audio. I'm in an experimenting mood, so make this another addition to my order. :D
    Edit...I'd prefer no writing on these.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    VR3 Posts: 29,533
    You guys are a trip. 😜
    How many rings would you need good sir
  • JayCee
    JayCee Posts: 1,509
    I'll just do 1.2's, so 16. Don't think it's for low bass but thoughts on the PR?
    VR3 Posts: 29,533
    I don't think you would see any benefits doing the pr.
    I will look into it tonight, I'm pretty sure a teeter faceplate would fit in the inner circle so I wouldn't be wasting alot of material to cut them, will figure out pricing and update!
  • JayCee
    JayCee Posts: 1,509
    edited March 2021
    VR3 wrote: »
    I don't think you would see any benefits doing the pr....
    Had the same thoughts but wanted your confirmation. Don't worry 'bout it....see bold. Only real consideration will be if, aesthetically, it completes the matching look w/MW's. I was thinking, also, in the PR size dead space you could get MW's and the smaller round tweeters to really maximize minimize the waste?
  • machone
    machone Posts: 1,562
    I would like one set for my 2.3TLs. paypal?
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    VR3 Posts: 29,533
    Sounds good, I will send a pm!
    Looking at how the grill sits on the baffle, the best route would be rings that rest between the basket rim and the edge of the surround, this would have adequate results for the purposes we are seeking. I thought about doing something that would fit like a puzzle piece to line up with tweeter pads but I dont think there would be any benefit and may actually look a little funny.
    I am thinking I could do the midbass rings at $8 each plus shipping on the total which would be $4.50 or $8.50 depending on the quantity of rings.
    VR3 Posts: 29,533
    Side note, I dont see any benefits at all to do this with a passive radiator taking into consideration with a PR does and how low it sits to the floor.
  • JayCee
    JayCee Posts: 1,509
    VR3 wrote: »
    My thought, too, and, from experience, it takes a chitload of room treatment's to go after those frequencies. Just thinking out loud. May be more of an option to match the MW's for a more thought out look/uniformity. I think Larry or his fabrication buddy built ring covers to bling the drivers up?
    VR3 Posts: 29,533
    The beauty rings would look cool, but actually could add diffraction depending on how it is implemented, would need to know more, as in did they curve it away from the surround back to the basket edge, etc?
    I could make a PR ring but it would need to be 2 pieces unfortunately since the size exceeds my printing capabilities
  • JayCee
    JayCee Posts: 1,509
    Easy....buy a bigger printer. BAM! I think I'm good for now. You've shattered my piggy bank.
    pitdogg2 Posts: 27,228
    I'm thinking you may have enough liquidity to get a bigger printer when all is said and done ;)
    VR3 Posts: 29,533
    I think the next step is to teach the wifey how to use it and print out diffraction pads hahha
    VR3 Posts: 29,533
    Can see the memory of the material here
    VR3 wrote: »
    Don't go and get greedy ☺️☺️
    VR3 Posts: 29,533
    One can wish! Hahaha
  • honestaquarian
    honestaquarian Posts: 3,258
    VR3 wrote: »
    You know her ears are burning🔥 right now right??? :s
