New Thread: Diffraction Pads/Rings
VR3
So my first thread kind of went crazy, sorry for making a different thread, but it seems to make sense.
So I can make any type of diffraction pad (within reason) so any dimension, shape, etc.
They are made of wool/felt and are laser cut/engraved.
They can be easily attached with velcro strips/dots.
Below are some examples.
Pricing examples are as follows, for a pair, with shipping.
1.2TL Pads, $37
2.3TL Pads, $29
Single tweeter $15
Diffraction ring $12
Minimus 7 Pads $22
Diffraction is what happens as the sound wave extends across the baffle and interacts with screws, grills, baffle edges, etc. An example of that is below -
Some examples -
1.2TL Pads, $37
2.3TL Pads, $29
Single tweeter $15
Minimus 7 Pads $22
Some examples -
Interesting...I wonder if they would work with the KEF R3 Uni-Q driver."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
Would be fairly easy to do a simple ring that went around the woofer for sure. Alot of coax drivers have a felt/foam ring around the tweeter as well- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Here's a photo of the classic Spica TC50 designed by John Bau.
Excellent, looks like he had those punched and the grills completed it. Great design
@Clipdat that is what we will do with yours- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
1.2tl
It would be awesome if you can make me some for the 2 front Infinity EMIT tweeters when you put my crossovers together. For a fee of course.
Absolutely, I would just need a tweeter or really detailed measurements!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Would the SDA benefit from greater coverage like the Minimus?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
I do believe a ring around the midbass driver that fits between the surround and the basket edge would be beneficial.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I would like to try one of those too^^ I wonder which is the worst offender......the basket rim (which really sticks out in un-rabbeted vintage monitor baffles), or the right angle cabinet edges.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Really the whole baffle and grill, plus the baskets would cause diffraction, the drivers themselves would cause some diffraction from other drovers. Very little was done to combat diffraction with the sda.
I have some midbass drivers here, will see what I can draw up
My very early 7B's have a grill cover where the particle board frame is not even rounded over on the inside. That can't help. I have been listening for many months without them but now with all the mods making the speakers more transparent and even a bit bright and revealing sometimes, I thought I would try putting them back on. More mellow sound for sure, but those sharp inside corners got me thinkin'.George / NJ
iFi nano iDSD DAC
iPurifier3
Sid,
Shut up and take my money!!
AR did this type of thing with the AR9 series Acoustic Blanket...
Well done, sir!I plan for the future. - F1Nut -
Edit...I'd prefer no writing on these.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
You guys are a trip. 😜
How many rings would you need good sir- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'll just do 1.2's, so 16. Don't think it's for low bass but thoughts on the PR?➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
I don't think you would see any benefits doing the pr.
I will look into it tonight, I'm pretty sure a teeter faceplate would fit in the inner circle so I wouldn't be wasting alot of material to cut them, will figure out pricing and update!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I don't think you would see any benefits doing the pr....
Had the same thoughts but wanted your confirmation. Don't worry 'bout it....see bold. Only real consideration will be if, aesthetically, it completes the matching look w/MW's. I was thinking, also, in the PR size dead space you could get MW's and the smaller round tweeters to really maximize minimize the waste?➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
I would like one set for my 2.3TLs. paypal?Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Sounds good, I will send a pm!
Looking at how the grill sits on the baffle, the best route would be rings that rest between the basket rim and the edge of the surround, this would have adequate results for the purposes we are seeking. I thought about doing something that would fit like a puzzle piece to line up with tweeter pads but I dont think there would be any benefit and may actually look a little funny.
I am thinking I could do the midbass rings at $8 each plus shipping on the total which would be $4.50 or $8.50 depending on the quantity of rings.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Side note, I dont see any benefits at all to do this with a passive radiator taking into consideration with a PR does and how low it sits to the floor.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Side note, I dont see any benefits at all to do this with a passive radiator taking into consideration with a PR does and how low it sits to the floor.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
The beauty rings would look cool, but actually could add diffraction depending on how it is implemented, would need to know more, as in did they curve it away from the surround back to the basket edge, etc?
I could make a PR ring but it would need to be 2 pieces unfortunately since the size exceeds my printing capabilities- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Easy....buy a bigger printer. BAM! I think I'm good for now. You've shattered my piggy bank.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
I'm thinking you may have enough liquidity to get a bigger printer when all is said and done
I think the next step is to teach the wifey how to use it and print out diffraction pads hahha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Can see the memory of the material here
Don't go and get greedy ☺️☺️ -
One can wish! Hahaha- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
