Anti diffraction rings (for tweeters)
245
  • JayCee
    JayCee Posts: 1,502
    B)
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    VR3 Posts: 29,383
    Here is 2.3TL overlay
  • honestaquarian
    honestaquarian Posts: 3,260
    What about the 3.1TL's?
    VR3 Posts: 29,383
    Yes sir, I just need to know the total height including the diffraction strip that came from the factory above it
  • honestaquarian
    Total height of the entire speaker or just the tweeter?
    VR3 Posts: 29,383
    I would need to know the measurement from the bottom of the tweeter to the top of that strip in the photo
  • honestaquarian
    Is anyone else having trouble tonight with the forum?
    I’m trying to upload a pic and it won’t let me do it.
    Keeps timing out.
    Anyway 4 5/8” inches
  • JayCee
    JayCee Posts: 1,502
    Keeps timing out.
    Yes, tried to load a few pics and get something like a "failed to upload" error. Tried 2 different browsers and no luck.
    pitdogg2 Posts: 26,917
    edited March 2021
    Yes Carlton I have been fighting that all night. Keeps saying something about vanilla servers. Something is amiss.
    VR3 Posts: 29,383
    I will draw up a mock up for the 3.1 tonight and update.
    I was having issues as well with pictures, I used url links from old posted photos in half the pics
    xschop Posts: 5,046
    edited March 2021
    Will the AD rings negate the need for that plastic strip across top of tweeter?
    Really cool, yet functional upgrade either way.
    VR3 Posts: 29,383
    It should negate the need for the strip but also wouldn't hurt to leave it either
    xschop Posts: 5,046
    In that case, I'll take a pair for the 8TLs when they are ready. Thanks for making these available.
    VR3 Posts: 29,383
    the dark line up top will be a route out to give it a bend
  • honestaquarian
    So the material would go onto the tweeter faceplate AND the diffraction strip above it?
    VR3 Posts: 29,383
    Yes
    I could include two pairs, one without and one with four you to compare as well.
    VR3 Posts: 29,383
    The way that strip is designed it looks like it would interact with the midrange driver as well, so would need to test both to come up with the best solution
    gudnoyez Posts: 8,156
    Where would the velcro dots be mounte, in between the top and bottom of the RDO198's, using two dots or on each mounting screw using 4 dots? No question is to dumb right? I might pick up a pair for 2.3tls.
    VR3 Posts: 29,383
    I would probably do the top two mounting screws and then two dots below the tweeter, leaving the bottom two mounting screws floating. (for a single tweeter)
  • drumminman
    drumminman Posts: 3,396
    Trey I’m interested in a pair for my 2.3tl’s. Let me know when you can have them available.
    VR3 Posts: 29,383
    I have more material arriving today, once I have everything cut, let me see if I need to order more to make for the 2.3
    I used the little doughnut rings on mine today for about a hour and I couldn't believe the difference, totally forgot how much improvement these things bring
  • stevep
    stevep Posts: 357
    Those tweeters seriously need washers on the back side of the mounting screws.
  • JayCee
    JayCee Posts: 1,502
    Aw, hell. Add 3.1tl's to my order. Please PP me and I'll send more $.
    VR3 Posts: 29,383
    Inquiries not invoiced yet -
    @xschop RTA8TL (one pair with the tab and one without)
    @honestaquarian 3.1tl (one pair with the tab and one without)
    @JayCee 3.1tl (one pair with the tab and one without)
    @Drumingman (one pair 2.3)
    @gudnoyez (one pair 2.3?)
    @muncybob (2b)
    Not sure if I missed anyone else??
    VR3 Posts: 29,383
    2.3tl!
  • honestaquarian
    stevep wrote: »
    Larry’s rings are behind all of the drivers. Which is why you don’t see the regular Phillips screw there and instead you see the Allen screws. I did this during the big, giant dreadnought group buy of 2016. I also got Trey to do the crossovers. You can see the upgrades in my thread about it.
    VR3 Posts: 29,383
    On the 3.1tl, I'm including two sets so you guys can give me feedback, price includes both pairs
  • stevep
    stevep Posts: 357
    stevep wrote: »
    The RDO tweeters need a washer under each mount point so you don't distort the bezel when you tighten them. I understand that those button head Allen bolts are also missing the countersink on the rear but that only makes the distortion of the bezel worse.
    However they're your speakers and this is a FS thread so I'll stop off topic posting.
  • honestaquarian
    VR3 wrote: »
    No washers on these either.
