Record player in the sun?
Trying to figure out if there would be any issues moving this...
To here...
  • Emlyn
    Emlyn Posts: 4,828
    Depends on whether the sun shines directly in that window at any point in the day. Window glass has some UV protection built in but not much and not enough even when combined with a normal curtain to prevent sun fade. If it's a north facing window I think that spot would be ok. But, it also looks like there's a heat vent in that spot.
  • hochpt21
    hochpt21 Posts: 5,423
    Yes, there is a heat vent.
    The back yard is pretty shaded, but there is some direct sun at times.
  • Emlyn
    Emlyn Posts: 4,828
    It could be ok there. May want to look into a sheet of UV resisting window film that goes on the inside of the window glass.
    Nice view!
  • hochpt21
    Thanks. This is what it would look like.
  • Emlyn
    Emlyn Posts: 4,828
    Looks good! Nice turntable setup.
  • hochpt21
    I actually think I like it better here, but currently in negotiations with the wife, lol.
  • hochpt21
    Kex wrote: »
    Ya know... we have a cabin in the mountains, and it’s facing full south. The windows have UV shades that come down in the full sun and they really filter out the heat extremely well. So well, in fact, that you can sit on the couch in direct sun, and not feel any heat at all. Aesthetically, IMO, they would look better than a curtain behind your turntable, and you could lower them easily at will when needed.
    Just a thought, in case of OCD! 🤔
    They come down automatically?
  • Emlyn
    Emlyn Posts: 4,828
    I agree it looks better the way it is where it's not blocking the window.
  • DaveHo
    DaveHo Posts: 3,583
    My concern other than sunlight would be the possibility of standing waves in that nook making for subpar TT performance. Not sure that's really an issue though.
  • jdjohn
    jdjohn Posts: 3,384
    I think the second position is better since it doesn't block the vent.
  • smglbrth
    smglbrth Posts: 1,499
    I like the 2nd position as well. Up north I, nor my wife, like to block the sun out. Especially in the winter when we don't see it much!
  • xsmi
    xsmi Posts: 1,804
    I have the same curtains! I like the 2nd position as well.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    txcoastal1 Posts: 13,519
    WAF overruled by the PAF (Polkie approved factor)
