Advice on 2 channel amp for SDA 2a
  • Kex - I got it from the service manual for the NAD 2600 (oops not 2600A), here:
    https://www.hifiengine.com/manual_library/nad/2600.shtml
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Gardenstater
    Gardenstater Posts: 4,742
    edited February 2021
    Just bugs me when a company says it clips at the same wattage regardless of 8 ohm or 4 ohm. Also, if it clips at 200W at 8 ohms and clips with a 20ms power spike at 8 ohms at 400W, then the actual dynamic headroom is actually 3dB, not 4dB, which admittedly is still very good but still.......
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • invalid
    invalid Posts: 1,441
    The parasound amps are a better bet than the NAD. The 2a's are hard on amps, I've blown up quite a few with my 2a's that I bought new in 1987.
    audioluvr Posts: 5,871
    I think you guys are getting a little too obcessed with specs. They are fine for a general guideline but the ultimate determining factor is how it sounds in your room on your system to you.
  • Not obsessed with specs but not everyone can sample everything out there and I would like to see companies being more helpful with the specs that are needed to assess the amps ability to respond to musical peaks at a given speaker load, especially lower than 8 ohms.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Smit
    Smit Posts: 31
    Thoughts on this guy....
    https://www.ebay.com/itm/Hafler-P-225-220-Watt-Upgraded-Stereo-Audio-Amplifier/402713910434?
    Specs - https://www.hafler.com/pdf/archive/P225_P230_amp_man.pdf
    It is a bit more than my budget but it has been upgraded with new components.
    Something I will have to do to some defree regardless of whatever 'used' amp I purchase. Much of this goes over my head - opinions, advice from you all appreciated.
  • invalid
    Kex wrote: »
    audioluvr wrote: »
    Absolutely agree. Specifications discussions are always somewhat arid.
    Not everything can be explained by numbers on paper, and NAD’s reputation belies the specifications. Which is why the casual statement of needing 200 wpc that is often bandied about, is almost cringeworthy.
    Do you own the 2a's? If you listen at high SPL's you will need an amp with a very robust power supply, even my adcom gfa555 didn't like them. The amp I have now runs them fine but it has a massive power supply that can drive 1ohm load.
  • Smit
    Smit Posts: 31
    I do own the 2a's. And I do like some volume. But the 75 wpc I have right now doesn't work.
    Smit wrote: »
    Not familiar with that particular Hafler but if the refresh is legit it should be a nice upgrade.
  • Gardenstater
    edited March 2021
    Supposedly (verification needed) that is the pro version of the DH-220, which was reviewed in Audio, Feb. 1984 p. 54
    https://worldradiohistory.com/Archive-All-Audio/Archive-Audio/80s/Audio-1984-02.pdf
    And also Stereophile Vol. 6, No. 5
    https://worldradiohistory.com/Archive-All-Audio/Stereophile/80s/Stereophile-Vol-6-No-5.pdf
    I would like the fact that many upgrade kits are available to upgrade it beyond what the seller did. Apparently they tend to run warm/hot. I would want to ask the seller if they know if the one in question was kit built or wired by mfg..
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • oldrocker
    oldrocker Posts: 2,590
    Saw this listing.
    https://www.audiogon.com/listings/lisa8ih9-parasound-hca-1500a-new-caps-installed-scratched-top-panel-solid-state
    A bit north of your price point and cosmetically challenged, is accepting offers.
    Had I seen this a while back, I donated a D220 during my purgeathon, you could of just had it.
  • Smit
    Smit Posts: 31
    So I missed the purgeathon.... story of my life. RRRR!!)
    Anyway, I am passing on the Hafler P230 due to price.
    Now it has come down to these two amps.
    Gonna pull the trigger on one of these for sure.
    Parasound HCA 1000A $350 (that includes shipping) - Audio Mart
    or
    Hafler 9270 $265 (that includes shipping) - ebay
    Both appear to be clean and working great (from pics and chats with seller)
    I really have appreciated the advice and opinions from everyone.
    Any opinions on these two??
    Both of these amps have great reviews but I'm leaning towards the Parasound.
    Thanks again
    -Smit
  • Smit
    Smit Posts: 31
    Got the Hafler 9270. Parasound was sketchy.
