Most fun I have had in a long time!
VR3
Not done but too excited not to post a pic or two!
1.2tl crossover. The V arrangement in the tweeter network allowed for almost no jumper leads, was excellent!
Very nice presentation and layout. Looks like a LOT of hard work that you made look easy. Those custom boards are trick.Don't take experimental gene therapies from known eugenicists.
You are the MASTER!"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Will the crossover be visible once installed?
Nope! Mounts right on the front crossover plate! π
Thanks guys!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Got it.
Hopefully the recipient of these is a forum member so we can get some before/after listening impressions. -
Did you use a stain on the wood to get it to look like that?
The main board is a wood species called "Chakte Viga" and the connector pieces are mounted in mahogany
All just have a simple clear coat- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Do those grow in NC???
I've watched that 'Swamp Loggers' show, but didn't see them harvesting any of that.
Someday we can say, "I knew Trey before he got famous...before his work was on display in the Guggenheim.""This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Super sweet! Too bad the end result is hidden. I'd have had you build one with a 3/8" thick lexan plate so you can see the awesomeness!Gustard X26 Pro DAC
There is about a 5% genetic difference between apes and men β¦but that difference is the difference between throwing your own poo when you are annoyed β¦and Einstein, Shakespeare and Miss January. by Dr. Sardonicus -
Unfortunately lexan can not be cut with a laser! Otherwise that would be sweet! I could use acrylic but acrylic can literally split into pieces, nothing like doing a build and then have it split in half!
Thanks guys! Dunno about being in the guggenheim hahhaa- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Apparently in South America they use those trees for fence post untreated and last 100 years? Go figure. Beautiful wood though, cuts great with the laser. Smoke pours out the exhaust like a chimney out the sid eof my house! I tape all of the seams of my printer before I hit the magical blue button though so it stays fresh inside with no smell!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I don't like it.
π’- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hot damn Trey, you do good work. Rock on with your bad self.HT SYSTEM-
lsi 9's -
Very, very nice.
Gorgeous nice jobHome Theater
Really nice man, great jobDan
Sean is going to be very happy when he gets these dawn undah!!
Thanks guys!
These are not for Sean, these are based off some of the parts that were in the speakers.
Seans build will be massive lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Can't imagine what the Monoliths' boards will emerge as.
Don't take experimental gene therapies from known eugenicists. -
Im excited to see the caps in person!!
Should be about this size...
WHOA!!
All done! π
Still don't like itπππ
Those must be the Duelund cast caps, those are supposed to sound awesome. I don't think too many people get ears on those, being they cost so much money. -
Thanks guys!
Im still sad @pitdogg2 hehe
I can't wait until they arrive, I think we have been waiting... 5 months?? But I've been told they would be here this month- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
PhenomenalYamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Thanks for the information
