FOR SALE: Bryston 6B-SST 3 Channel Power Amplifier
aboroth00
aboroth00 Posts: 1,108
edited December 2020 in For Sale (FS) Classifieds
Up for sale is my Bryston 6B-SST power amplifier (3 Channel). Second owner, which was pulled from a temperature controlled cabinet. Overkill for my current setup. Amplifier is in immaculate condition. It is currently at Bryston for a overview and will return to you better than before. New original box (180$) included. Buy with confidence. Also selling other amplifiers for those interested.
Bryston has been great with service and warranty. Amp was built in 2005 and has ~5 years remaining on warranty. They are great to work with, fast and responsive, and in my experience will service the amplifier as long as it's within warranty.
Power Output: 300 watts into 8 ohms, 500 watts into 4 ohms (3 Channels)
Input Impedance: 50 K ohms Single ended; 20 K ohms balanced
Distortion (IM or THD + noise): < 0.007% 20 Hz to 20 kHz at 300 watts, IM or THD
Power Bandwidth: <1 Hz to over 100 kHz
Damping Factor: Over 500 at 20 Hz, ref. 8 ohms
Dimensions: Rack Mount Version 19" wide, 7" high, 20.5" deep with handles; mounted rack depth - 18.3"; 17" version available 17" wide, 7" high, 19" deep
Weight: 80 lbs.
Asking 3122$. Local pick up preferred in 92677 but will ship fully insured also via Fedex ground. Packaged weight is 100LB.
2Ch Tube Audio Convert
