FOR SALE: Bryston 6B-SST 3 Channel Power Amplifier
aboroth00
Up for sale is my Bryston 6B-SST power amplifier (3 Channel). Second owner, which was pulled from a temperature controlled cabinet. Overkill for my current setup. Amplifier is in immaculate condition. It is currently at Bryston for a overview and will return to you better than before. New original box (180$) included. Buy with confidence. Also selling other amplifiers for those interested.
Bryston has been great with service and warranty. Amp was built in 2005 and has ~5 years remaining on warranty. They are great to work with, fast and responsive, and in my experience will service the amplifier as long as it's within warranty.
Power Output: 300 watts into 8 ohms, 500 watts into 4 ohms (3 Channels)
Input Impedance: 50 K ohms Single ended; 20 K ohms balanced
Distortion (IM or THD + noise): < 0.007% 20 Hz to 20 kHz at 300 watts, IM or THD
Power Bandwidth: <1 Hz to over 100 kHz
Damping Factor: Over 500 at 20 Hz, ref. 8 ohms
Dimensions: Rack Mount Version 19" wide, 7" high, 20.5" deep with handles; mounted rack depth - 18.3"; 17" version available 17" wide, 7" high, 19" deep
Weight: 80 lbs.
Asking 3122$. Local pick up preferred in 92677 but will ship fully insured also via Fedex ground. Packaged weight is 100LB.
Weight: 80 lbs.
2Ch Tube Audio Convert
One sweet piece of equipment 👍
That's a heck of an amp and I'm local. Too bad I'm broke. :'(
Price dropped to 2955. Amp returned from Bryston in original packaging with a clean bill of health. Biases on all channels were adjusted to factory specifications.
2Ch Tube Audio Convert -
This is really tempting. But I absolutely love my Aragon 8008x3. Hmmmm.
The question is... whether the Bryston is better?
Seems like little to no difference than the 6BSST2 in the current Bryston line-up which retails for 10.1k$2Ch Tube Audio Convert -
Good luck with the sale, They are probably my favorite amps, If I needed it, it would be mine. Someone's gonna get one hell of an amp.Dan
Sold! Took much longer than I thought for a quality piece.2Ch Tube Audio Convert
