Just got LSiC
lomic
lomic Posts: 407
edited February 2005 in Speakers
Been using CSi3 for quite a while now, and have really been looking forward to getting the LSi counterpart.
First thing I was worried about was being able to pinpoint the fact dialogue only comes out from the right woofer. Even though my couch (unfortunately) is only 5 feet away from the center, it's pretty much impossible to tell only one woofer is firing for voice. From this I quickly noticed how well the cascading crossover really works, I can sit anywhere off-axis now and still recieve clear voices. With the CSi3 it was very noticable if you were out of the sweet spot, which was maybe only 5 to 10 degrees in each direction.
I know my 7's took a while to get un-muddied out of the box, so I guess I'm going to have to go through it again. They were never really as obvious, since they don't host voice very much, but the LSiC is definitely in need of break in. Of course, it probably doesn't help I'm using a 50 cent RCA IC and 16-18 AWG monster cable, vs. Frank's Shotgun BW and Analog 2 IC on my 7's, so hopefully once I the new cables get here, and a couple weeks of break in, everything will be golden :)
Last task is to let my roommates re-arange the living room along the verticle instead of horizontal - I suppose any speaker will have a bit of an edge from 5 feet away :p
Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP)
Post edited by lomic on
  • Early B.
    Early B. Posts: 7,900
    Very nice system you got there. Should sound awesome, especially with music.
    "God grooves with tubes."
  • Joey_V
    Joey_V Posts: 8,600
    I'm really thinking about getting an LSiC to complete my setup. I have been a strong proponent of 4.1 especially since my room is quite small relative to the theaters some people here have... ehhehe.
    Anyway, I should be getting one in two months or so.
    Looking forward to it!
    Also, if you could post a review of the LSiC after break in, it would be much appreciated!
    :D
  • lomic
    lomic Posts: 407
    Hmm.. well I think I figured out what was causing the smallness and muffled vocals!
    Try replacing this:
    With this:
    Thanks to Frank! Just needs a little more break in, but sounding insanely great already.
  • Early B.
    Fantastic! Who says cables don't make a difference???
    Are the old speaker cables Monster brand? If so, burn them before they end up in another system.
  • lomic
    lomic Posts: 407
    Strange, I accidently dropped some holy water on those monster cables and they burst into flames. Who'da thunk it?
    I finally did a real reacalibration - and just became insanely glad I replaced the CSi3. I'm pretty new to home audio, so I thought what I had before was a pretty convincing "soundstage", but no, no, no.
    It's like there's now a virtual curtain in the front of my room, and it's all emiting sound evenly over the entire surface. I played some DTS music and in one of Sting's songs imaged so well I could hear his voice coming from the lower left corner of my amplifier. Freekin' amazing.
  • phuz
    phuz Posts: 2,372
    Ok that's it, I'm ordering my cables like... NOW.
    Congrats, those cables look great and I bet they sound even better.
  • Joey_V
    Joey_V Posts: 8,600
    Hey you should post some pics of your system and the lsic... i would like tou see it and im sure others would too!
  • Toxis
    Toxis Posts: 5,116
    I'm still seeing a lot of cheap-o cables in there... :D Time to start upgrading!
  • lomic
    lomic Posts: 407
    Sure thing. Unfortunately having housemates (who pay much more rent) limits me from organizing the living room the way I'd like it. Subwoofer is right next to TWO openings. Oh well, I think they'll come around eventually :)
    Here's the moneyshot of the whole system. I know the speaker stands should be higher in theory, but I got them for $15 bucks direct from Vidsonix on eBay so they sound GOOD to me! Those VHS tapes aren't mine, I swear...
    Again, I really don't like having my Parasound sitting atop the HK, but I have to deal with it for now. Gets a bit hot but never gone into protection mode.
    Housemates also have a cat, hence the blanket ontop of the sub. He doesn't get up there often, but I'd like to preserve resale value for when I go SVS. I think this sub is actually my favorite part of the system, though.
    Taking a bit of advice from Polksters, using Home Depot rubber doorstops to angle my LSiC downwards. Works very, very well.
    If anyone wants to see anything up close, feel free to ask.
  • lomic
    lomic Posts: 407
    Most of the cheap-o cables are things I don't care about, like their old VCR, Xbox and PS2 that I never play and the DISH reciever, which only has composite out for audio. Using component directly to the TV for DVD.
    Only 2 cables I want to upgrade are a MagicPower cord - even though the Parasound did come with what I've heard is a very good stock cord - and the Digital Coax, once that's gone I'll be rid of Monster forever.
  • Toxis
    Toxis Posts: 5,116
    What size/brand stands are those? They look like the Target Audio HR60's (22"). Am I right? I am looking at getting the 70's (28") and was curious to see what you thought of 'em. I don't think they look to bad... a little pricey but not bad.
  • lomic
    lomic Posts: 407
    They're Vidsonix, at the bottom of the page here:
    http://www.vidsonix.com/vidsonixnew/vidsonix_accessories.htm
    like i said, got them for $15 on eBay direct from the company.
  • Joey_V
    Joey_V Posts: 8,600
    So is the LSiC piano black all the way through? Is there an adjuster in the back to tilt it forwards and downwards?
    I would like a pic of your system without the speaker covers... thanks!
    Looks nice!
  • mantis
    mantis Posts: 17,322
    Hey I see a Pioneer Dv414 in your system. I use to own that DVD player. I bought it the week it came. I remember all the reveiws of it back then and it got a really good rating. My sister now uses it and it still looks brand new.
    Dan
    O nice system :cool:
    Dan
