Cambridge 851N and Tidal Connect
rburgess714
rburgess714 Posts: 621
edited January 2021 in Electronics
With firmware update I now have the Tidal app in the Cambridge Connect under the apps section and can tap on the app which opens the native Tidal app and then must tap the speaker icon to stream through the 851n. It displays as an AirPlay connection, is that correct? Is the quality through AirPlay the same, better or worse than steaming through the older version that requires you to access Tidal through Media-Services and Tidal.
The first 2 screenshots are the old way of connecting to and the later with the new app update.
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
  • gyosa
    gyosa Posts: 770
    Incorrect methodology ...
    Download the tidal app , and stream to 851 via the tidal app.
    There will be a little “speaker” icon bottom left .... select 851n
    Streaming anything thru airplay is inferior sound quality.
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • rburgess714
    edited January 2021
    gyosa wrote: »
    Bk
    Hey I may not have described the pre firmware update post update correctly .. I do have the app on my phone but with the new firmware you can launch the native Tidal app through CA Connect and it looks and operates as such. In both scenarios you tap the speaker and are given options of devices to stream. Where I am confused or possibly not explaining is that whether I launch Tidal from phone or the CA app both are streamed via Airplay to the 851n.
    Living Room
    Office
  • displayname
    displayname Posts: 1,248
    gyosa wrote: »
    Bk
    Here's how it works on my CXN.
    Open the StreamMagic app, go to the device settings, make sure you have early update turned on, then download the latest firmware.
    Once that's done, open the Tidal app. You don't need StreamMagic at all once Connect is going.
    On the available devices you should see your streamer with "TIDAL Connect" under it.
    On the unit display you'll likely see a slightly different look as well.
    This is assuming the 815 will be working the same as the CXN.
    Discogs
  • rburgess714
    I have the latest firmware and the 851 showing up as device to connect to but it doesn’t say Tidal connect. Perhaps the 851N doesn’t allow for Tidal Connect though the support site says it does. I opened a ticket with CA.
    Living Room
    Office
  • rburgess714
    Got it there must have been a firmware upgrade issue on the phone app or phone issue. Regardless was able to upgrade...all set thanks.
    Living Room
    Office
    Clipdat Posts: 13,107
    Nice!
  • displayname
    I just want to say my favorite part of this update so far is not only completely bypassing StreamMagic, but also bypassing my phone. I'm able to just connect via Tidal on my computer now, which couldn't be done before. I'll still use the Tidal app on my phone regularly, but when I have my computer in front of me, it just saves another step. And no need to add StreamMagic to multiple devices (like tablets or other computers). As long as I have Tidal, I'm good to go. Still hoping this Connect feature just becomes the standard for all streaming services.
    It still doesn't eliminate the need for apps for those using their own files, but for the streaming services, it's hard to beat.
    Discogs
    audioluvr Posts: 6,079
    How are you doing this? I still haven't figured it out?
  • gyosa
    gyosa Posts: 770
    Any glitches or problems with early update firmware ?
    Thinking about upgrading , but not to comfortable being a beta tester ...😂
    Bk
  • displayname
    audioluvr wrote: »
    I can get a screenshot off the computer at some point, but just open Tidal on your computer. On the bottom right there is the same speaker logo that's on the phone app. Same process as the phone, just opposite side of the screen.
    Discogs
  • displayname
    gyosa wrote: »
    Bk
    Only one very minor one so far.
    When playing from the computer, if I jump from a song playing in a playlist mid song to a new track from another album or playlist, the first note plays twice. A very minor thing, and only happens when I'm bouncing around mid track. It's pretty clean so far.
    Discogs
    audioluvr wrote: »
    I only have the computer speakers as the option unless I plug in my USB cable. Still only shows "USB Audio" only on the 851 display. In the "More Settings" I can turn on/off three things, "Use Exclusive Mode", "Force Volume" and "Passthrough MQA" None of which I know whether I need on or not. Thoughts? Maybe I need to do a factory reset.
  • displayname
    audioluvr wrote: »
    audioluvr wrote: »
    Did you update the firmware on the Cambridge yet?
    Discogs
  • gyosa
    gyosa Posts: 770
    Thanks !
    Bk
    gyosa wrote: »
    Bk
    Yes. I can use the Cambridge app on my phone for Tidal but that's all. The Tidal app on my phone does not have a speaker in the bottom left.
  • displayname
    audioluvr wrote: »
    Screen shot? You may need to update Tidal on your phone too.
    Discogs
  • displayname
    This is what you should be looking for.
    Discogs
    edited February 2021
    When I click that I get this
  • DaveHo
    DaveHo Posts: 3,586
    Router reboot? Just thinking out loud.
  • displayname
    Yeah, not sure. I updated Tidal, updated Cambridge, and everything was there flawlessly as promised.
    Discogs
    Tidal is updating all the time. Just updated again today. Nothing. I guess I'll try a factory reset on the 851 and see if that will let Tidal recognize it.
    Update: Well that didn't do anything other than loose my presets...
  • displayname
    audioluvr wrote: »
    Make sure you have early updates on the Cambridge turned on too.
    Discogs
    Factory refresh updates it to the latest everything. Yes auto update is on. Thinking it's got to be Tidal... which says it's updated.
  • displayname
    audioluvr wrote: »
    So auto update and early update are not the same in StreamMagic. Make sure early update is on too.
    Discogs
    Ah. That's in the streammagic app. I didn't have that installed. I was using the Cambridge app on my phone. That apparently updated the 851 better than the 851 does by itself! :D
    Working now. no USB cable hooked to my computer any more! Yay!
  • rburgess714
    Hey interesting response I got back from CA support after having issues with TidalConnect, which I was able to resolve.
    “Tidal Connect and AirPlay would both stream the same audio quality (CD-quality or 16/44.1kHz). Since the 851N does not have an MQA decoder, the 851N will not be able to unfold any MQA files sent to it, regardless of whether it is coming through AirPlay or Tidal Connect.
    One advantage of using Tidal Connect is that it acts like a remote control for the unit and will not use as much of your device's battery. This is Similar to how the StreamMagic or Cambridge Connect act as a remote for your unit. AirPlay, on the other hand, will send the audio data to the 851N directly over your wifi network. The choice between the two, since the qualities will be the same), comes entirely down to personal preference.”
    Living Room
    Office
  • displayname
    That makes sense. I don't use Airplay (android/pc), but the logic makes sense. Does Airplay do gapless playback? The big downside of Chromecast on the CXN was that it wasn't gapless.
    Discogs
  • gyosa
    gyosa Posts: 770
    here's what I don't get...... I understand the 851 can't unfold mqa tracks , but if Mconnect can do the first unfold and send it to the 851 why can't tidal connect do the first unfold and send it to the 851 ?
    I don't really care about mqa , per se , just like the higher bitrate the first unfold gives ....
    Bk
    Just say no to DRM.
  • rburgess714
    I think AirPlay does do gapless but I have been using Tidal Connect with the new update.
    On a different note I have noticed on longer tracks it will drop or cutoff at 6 or 7 minutes. This didn’t happen with Tidal through StreamMagic but using the native Tidal app is so much better and I would think this bugs will be worked out over time.
    Living Room
    Office
