Infinity RSII....??? Any one had ears on them?
11112131416
  • CH46E
    CH46E Posts: 3,595
    Went and hooked up a buddies new system. Emotiva TA100 and KEF Q350s. That little Emo rated at 50 watts per @8ohms..... and the KEFs are 8 ohm and 87bd. Wow, that little combo jams man! I gave him some AQ RCA and he picked up some AQ Bedrock speaker cables with Nakamichi ends. Courtesy of @geppy1
    nooshinjohn Posts: 25,877
    Quit yer stallin' and get back to work on the Infinity's... We have waited long enough for you to get them hooked up and reviewed!
  • gp4jesus
    gp4jesus Posts: 2,016
    edited January 2021
    CH46E wrote: »
    Where and how much for that Soldering station?
    and...
    https://us.v-cdn.net/5021930/uploads/editor/6z/i11syvrozytc.jpg
    Armaflex/pipe wrap is thinner, much cheaper and easier to work with. I’ve used it on driver frames and any surface bigger than 3” X 3” inside all my speakers. A little contact cement helps.
    Hope that helps and thanks for the soldering station info.
    Tony
    *all connected w/Premiere ICs
    pitdogg2 Posts: 26,923
    That is very nice...
  • CH46E
    CH46E Posts: 3,595
    gp4jesus wrote: »
    CH46E wrote: »
    and...
    Tony
    Tony, I got it on Amazon for $39.00.
    https://www.amazon.com/dp/B08F28F7YB/ref=cm_sw_r_cp_apa_i_KBiaGbC56BT8E?_encoding=UTF8&psc=1
    Its heavy and feels like its well built. We will find out how it does in a few hours. Fingers crossed 🤞
  • CH46E
    CH46E Posts: 3,595
    What a mess. And I can't find my PTFE tubing. Or my zip ties :s
    audioluvr Posts: 5,866
    Lots of pretty colors! That board looks too thin. If you were closer, I'd help. Looks like a fun project.
  • CH46E
    CH46E Posts: 3,595
    The wood is 1/8 inch thick. Feels pretty sturdy. I'll be putting anti vibration feet on it so it can sit of the rear of the cabinet.
    I still can't find my PTFE tubing or zip ties. I have no freaking idea what happened to them. I had everything stashed in the same place. Uuughh!!!! 😬
  • CH46E
    CH46E Posts: 3,595
    I have a few caps here that have one short lead and a long lead. ????? What does this mean?
  • CH46E
    CH46E Posts: 3,595
    I found this. So does it matter what direction I go? This caps will all be in series. So input vs output ? Not really pos vs neg?
    "The line on the label (at the shorter lead-out end) indicates the outer foil. This should be connected to the point of lowest impedance/signal output / AC end."
  • CH46E
    CH46E Posts: 3,595
    As far as I've gotten so far. Taking a break now.
    An alternative to this would be a copper buss bar like this.
    https://www.ebay.com/itm/Copper-Main-Bus-Bar-Ground-Bar-Strap-5-8-x-12-1-2-03J37/184616991955?hash=item2afc07bcd3:g:NZwAAOSwSJpf~H2-
    You could also point to point wire them using any quality speaker wire.
  • CH46E
    CH46E Posts: 3,595
    audioluvr wrote: »
    Thanks. I think I'm going to do point to point. I have some really nice silver plated 14 awg wire that I will use for ground and to wire the woofers.
  • CH46E
    CH46E Posts: 3,595
    edited January 2021
    It ain't pretty. I have the tweeter and midrange section done on one speaker. Will put the woofer section in tomorrow.
  • CH46E
    CH46E Posts: 3,595
    Woofer section in. Now I need to connect everything to ground. I tried spacing the coils out as much as possible and changed thier orientation.
    All the parallel parts had my brain in overtime.
    Now all you need is a shouldered eye bolt and an engine hoist to set them in place :D
  • CH46E
    CH46E Posts: 3,595
    You can see where I started, everything crammed together. I was not sure there would be enough room. But there eneded up being plenty.
  • CH46E
    CH46E Posts: 3,595
    edited January 2021
    Are changing inductors worth the cost? I've heard it can be tricky getting the right coil. DCR has to be taken into consideration?
    Can I go from a iron core to a air core as long as awg wire and mh values are the same?
    There is a tiny .05mh iron core that I accidentally pulled about two inches of wire oot from under the protective coating. I think I screwed it up.
    Post edited by CH46E on
    It's probably fine. I had a dog chew up one of mine. I think it sounds better now.
  • CH46E
    CH46E Posts: 3,595
    I think I might be able to remove the protective coating and reminds the 2 inches i pulled out. The iron core is only as large as a pencil eraser.
  • CH46E
    CH46E Posts: 3,595
    This is the little coil I accidentally pulled about two inches of wire out of. I'm guessing I have to re wrap that 2 inches right??
    as long as the enamel is still intact, that is the path I'd try.
  • CH46E
    CH46E Posts: 3,595
    Yes. The enamel is still there. Does it have to be wrapped perfectly one wire in front of the other?
    CH46E wrote: »
    Not really ever seen polks? They look hand wound as fast as they could lol
  • CH46E
    CH46E Posts: 3,595
    I have not made the input to the crossover connections yet. I'm thinking I may make them bi-amp capable. Just in case I want to try that later. Would be very easy at this point.
    CH46E wrote: »
    I wouldn't do that... reason being is that it is just not needed. You can get a monoblock amp for each channel and that would be plenty.
    msg Posts: 10,450
    Hurry up, Chris.
    I'm waiting to hear how Baby Shark sounds on these things.
  • gp4jesus
    CH46E wrote: »
    go for it
  • automojo
    automojo Posts: 1
    edited October 2021
    Just my experience-your better off using a modern high quality electrolytic (new-not NOS) in the bass/woofer section, vs a thick wound poly.
    The thinner windings of the electrolytic are better suited for quick response-and at those low frequencies-as well as saving a ton of space-and throwing of your bass box volume.
    Plus you can use the saved cash for say Jatzen Alumen Z"s on your mids and tweets.
    That's where you will hear real improvement-not putting large value poly's on your woofers.
    I recently saw a racap of a RSiiia-where the guy used 1200uf of poly's!!!
    Sorry-poly's/film foil's aren't going to improve anything at those frequencies.
    Frankly non of them-that I'm aware of- is designed to improve anything in that range.
    The only reasoning-if they fit-is longevity-not sound.
    Modern electrolytics in a non heat environment should be good for 20 year min
    The Superior z's are great caps-a easy choice.
    Mids-I would look @ Alumen z's-or use a 25% AL Z' mis with 75% Clarity CSA-killer mix.
