Stereo Too Complicated
When does stereo equipment get too complicated also expensive? Sounds wonderful though.
https://www.youtube.com/watch?v=zaG5d98zVC0
Puritan PSM156
  • mantis
    mantis Posts: 17,316
    That's what is so fun about this hobby, mild to wild with really no ceiling.
    Dan
  • marvda1
    marvda1 Posts: 4,936
    it would take me a month to set that system up.
    Puritan PSM156
    mhardy6647 Posts: 34,917
    Mine's simple. One switch to turn it on or off.
    Source selector.
    Volume control.
    I mean, what else is needed?
  • erniejade
    erniejade Posts: 6,321
    It's not an equalizer? Yes it is or at least a form of DSP.
  • delkal
    delkal Posts: 764
    edited January 2021
    erniejade wrote: »
    It is the same thing MIT speaker cables do. But adjustable for your system. Since MIT cables have a big following here (I never heard one) I can only assume it would be better.
  • pearsall001
    pearsall001 Posts: 5,233
    One has to wonder if he actually just takes a seat in a nice comfy chair, sits back, relaxes & simply enjoys the music. Possibly with a nice adult beverage or two.
    I'll bet he can't, he's constantly listening to the gear but not enjoying the music.
    audioluvr Posts: 5,875
    Maybe he has an equalizer monkey that adjusts the contour for each musical track. They can be hard to train but the rewards are great! Cleaning up the **** is the only drawback.
  • RamZet
    RamZet Posts: 792
    You use to be able to save a EQ per track in iTunes, it was kind of cool.
    B&W CM9Classé Sigma
  • kevhed72
    kevhed72 Posts: 5,126
    I stopped watching when he pulled out the diagrams...
    msg Posts: 10,450
    Source selector.
    Volume control.
    Speakers?
    msg wrote: »
    Source selector.
    Volume control.
    Speakers?
    Well, yeah, but in terms of controls and switches 'n' stuffs. B)
    Actually, there are two L-pads on each speaker "system" -- derp.
    Hoist by my own petard, again. ;)
    Tony M Posts: 11,567
    edited February 2021
    I think another member's and my own Kenwood C2 ( which I have 2 of and have been using it for the past couple of months or more ) performs those tone adjustments.
    The guy had 5 areas, we have 4.
    I know, I know... :)
    But still;
    ^^^ a cute little preamp. :)
    I do wish it had remote control. ;)
