shielded or not
bolelet1
bolelet1 Posts: 92
Have one question for you guys: Does it matter if a sub is magnetically shielded or not. Thanks.
Post edited by bolelet1 on
  • Willow
    Willow Posts: 11,339
    edited February 2005
    how close is it to your TV ?
  • bolelet1
    bolelet1 Posts: 92
    I am placing it right behind my Mitsubishi HDTV about 1 foot away.
  • Willow
    Subs have a bigger magnet and it can interfere w/ your TV. Its best if it is shielded if it's goign to be close to your TV
  • Emlyn
    Emlyn Posts: 4,888
    The couple of times I moved an SVS PB2-ISD around in front of my RPTV, it knocked the convergence way out of whack and I had to reset it. The magnetic effect of a subwoofer driver can cause convergence drifting on an RPTV. It's not nearly as bad as the picture distortion problem caused by unshielded speakers and standard CRT or plasma TV pictures. So yes, I'd say it is best to keep some distance between, probably 2-4 feet from the lens mechanisms in the RPTV being plenty for an unshielded subwoofer driver depending on the size of the subwoofer.
  • bolelet1
    bolelet1 Posts: 92
    Thanks for the info. I will try to find a place for this sub and if not possible, I guess I will just have to get a shielded one. Can you tell me if the subwoofer in the RTi10 would be good enough?
