my monitor 4's veneer project.
So I decided to remove the vinyl laminate on one of my sets of 4A’s and veneer them with cherry wood (paper backed).
I used a heat gun, razorblade and some gloves. I heated up about a 5”x5” area at time and just pulled. It was definitely a learning curve. I found that heating up as much area as possible worked the best and pulling from back to front because of the wrap around on the front edge. After I all vinyl was removed I checked for damaged corners and filled them with wood filler. The corners on my 4’s were not that bad considering their age. I have decided to use titebond original glue for the adhesion. I will apply the glue to both surfaces and let dry (x3) then position and use an iron to reconstitute the glue. I think this will give me the best opportunity to align the wood grain on sides and top. If anyone has done this method I would appreciate some feedback on it. the other thing I am considering is to make a rabbit cut on the front edge (where the black part meets the wood veneer) to allow for the thickness of the veneer. Help on this would also be appreciated. I was able to remove one of the polk audio badge without breaking it. the other badge, well the post that goes into the wood snapped off, looks like I will have to glue it on.
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
  • dromunds
    dromunds Posts: 10,136
    Sweet. You gonna pop that binding post cup out and put in new caps and resistors?
  • I already put in a new clarity cap... They did not have any resistors, just one capacitor. No new posts. These are just basement workroom speakers.
    It's good experience in case I want to do the same to my 5s or 7s...
  • dromunds
    I love the Monitor 4 Peerless. I need to re-do the crossovers on mine.
  • What year? I will be interested to know what you have in them for the crossovers... I had 1, 5.8uf. I put in a 5.6 clarity. No resistors...
  • dromunds
    I’ll have to take a look at the crossover, I have yet to open them up. Serial numbers 20279 and 20280
  • I don't claim to be a finish Carpenter but I play one online... It's tedious but I am ok with my first go around on it. Front, one side and bottom guled up h81nq3wp9co4.jpg
  • Faustin
    Faustin Posts: 1,151
    Looking good. Polk 4's with Peerless were my first veneer job. Have since done 7's and RTA 12c's.
  • Faustin wrote: »
    Thanks... I don't know what to finish them with.... Any ideas? Tung oil?
  • Faustin wrote: »
    Did you use contact Cement or wood glue?
    pitdogg2 Posts: 27,179
    edited January 2021
  • Faustin
    wispolkboy wrote: »
    Faustin wrote: »
    I used PSA cherry veneer. If I remember correctly I used a natural stain and then applied several coats of hand rubbed satin polyurethane. Here is the thread:
    https://forum.polkaudio.com/discussion/161050/4a-overhaul#latest
  • Faustin wrote: »
    wispolkboy wrote: »
    Faustin wrote: »
    When you veneered your 4's I noticed that the port tube is white or is that the polyfil?
    Those look very nice!
  • JayMX
    JayMX Posts: 457
    wispolkboy wrote: »
    I own two pairs of 4‘s with Peerless. One pair has a white PVC port with walnut vinyl outside. The other is black with rosewood vinyl. Both will be getting the same treatment you just gave yours. I’ll be doing black walnut. Excellent work!
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • wispolkboy
    wispolkboy Posts: 150
    edited January 2021
    JayMX wrote: »
    wispolkboy wrote: »
    I like the black walnut! What source are you using for your veneer
  • JayMX
    JayMX Posts: 457
    wispolkboy wrote: »
    MacBeath has a location here in Utah but they will ship. The quality and selection is always good.
    https://www.macbeath.com/
    F1nut Posts: 51,894
    wispolkboy wrote: »
    Faustin wrote: »
    Sorry I didn't see this earlier. Cherry tends to show blotchy when dyed/stained or simply top coated. However, it looks better (IMO) with some color added, so adding a dye to a spray on clear coat gives the best result as the color and finish are on top of the wood, not in the wood.
  • Faustin
    "When you veneered your 4's I noticed that the port tube is white or is that the polyfil?
    Those look very nice!"
    The white that you see in thee photo is polyfil.
    F1nut Posts: 51,894
    My previous post should have said, ....or simply top coated with oil.
  • F1nut wrote: »
    That's what I ended up doing... Just minwax rubbing oil
  • JayMX wrote: »
    wispolkboy wrote: »
    Thanks for the link!
  • They look great! Awesome job.
  • @pelhamplace thank you, I appreciate it.
  • Gardenstater
    Gardenstater Posts: 4,787
    I think cherry is a beautiful wood and you did a really nice job! What did you end up doing at the front edge; did you rabbet it on the table saw or a router table prior to applying veneer where it abuts the baffle? What method of adhesion did you use for the veneer?
    As an aside, when I was a kid in high school I made a couple sand filled, cube shaped bookends out of 1/4" thick solid cherry (veneer lol?) over fir plywood, that the finish came out beautifully on. My 82 yr old mother has them in CO. I can't remember what stain I used but I do remember that the top coat was a satin lacquer, many coats.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • I think cherry is a beautiful wood and you did a really nice job! What did you end up doing at the front edge; did you rabbet it on the table saw or a router table prior to applying veneer where it abuts the baffle? What method of adhesion did you use for the veneer?
    Thanks,
    I used titebond type 2 for the glue. I applied to the veneer and speakers (one side at a time), let the glue dry and then used an iron.
    For the front, since this was a very early speaker '82, it was a right angle, not the beveled that polk went to in the mid 80s. I started the veneer on the front face, cutting out all four and making sure that the 45s were as tight as I could get it. The veneer was very thin, I think 1/40th of an inch. So I just left it as is. It stands out a little proud but not noticeable.
