Is this a cap?
wispolkboy
This is my crossover from what I believe is a monitor 5c.
Can you please tell me what this is. And if it is a capacitor what is the value in uf.
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
Best Answers
That's a flux capacitor filled with plutonium of course.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Both in your pic are capacitors. The values, uF and voltage for the light blue one will be printed on the case, but in your situation you'll have to remove the cap to see them.Political Correctness'.........defined
President of Club Polk -
@nightfall...well thank God I received some fresh plutonium for Christmas.... 😁
F1, so I picked away the hot glue and could see the value. Thanks..
What does the 13k represent?M7's 1982 Peerless tweeters
SDA 2 with upgraded tweeters -
God knows....Political Correctness'.........defined
Answers
I believe* and could be wrong, but that means it is rated for 13,000 hours before it would deviate from spec as per the manufacture- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
F1.... Why not, seems logical to me.
Thanks!M7's 1982 Peerless tweeters
Why not what?Political Correctness'.........defined
"Why not" is just a simple way of saying that your answer is very plausible /probable...M7's 1982 Peerless tweeters
wispolkboy wrote: »"Why not" is just a simple way of saying that your answer is very plausible /probable...
Ah, you were referring to the "God knows...." comment. Carry on.Political Correctness'.........defined
wispolkboy wrote: »What does the 13k represent?
It means 13 k small children in china were involved in the build and assembly. You should y proud! Or scared...
Edit. I mean MexicoGustard X26 Pro DAC
I am curious about the Monitor 5C. I am aware of the 5A, 5B and Monitor 5 Series 2, but not a 5C. If it is a 5A with Peerless tweeters, they are likely 12uF and 27uF capacitors. If it is a 5B then they are likely 12uF and 34uF. But you should look at your crossover components to get the values.Stan
Main 2ch:
HT:
Other stuff:
Skrol,
Sorry if I gave you a wrong impression of having a peerless. It does not.M7's 1982 Peerless tweeters
