Is this a cap?
This is my crossover from what I believe is a monitor 5c.
Can you please tell me what this is. And if it is a capacitor what is the value in uf. dp9j1s79ty70.jpg
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
Best Answers
  • Nightfall
    Nightfall Posts: 10,083
    Answer ✓
    That's a flux capacitor filled with plutonium of course.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 52,009
    edited December 2020 Answer ✓
    Both in your pic are capacitors. The values, uF and voltage for the light blue one will be printed on the case, but in your situation you'll have to remove the cap to see them.
  • wispolkboy
    wispolkboy Posts: 150
    Answer ✓
    @nightfall...well thank God I received some fresh plutonium for Christmas.... 😁
    F1, so I picked away the hot glue and could see the value. Thanks..
    What does the 13k represent?
    F1nut Posts: 52,009
    Answer ✓
    God knows....
Answers
  • jdjohn
    jdjohn Posts: 3,384
    God knows....
    What's his user name? I've got questions.
    VR3 Posts: 29,553
    I believe* and could be wrong, but that means it is rated for 13,000 hours before it would deviate from spec as per the manufacture
  • F1.... Why not, seems logical to me.
    Thanks!
    F1nut Posts: 52,009
    Why not what?
  • "Why not" is just a simple way of saying that your answer is very plausible /probable...
    F1nut Posts: 52,009
    wispolkboy wrote: »
    Ah, you were referring to the "God knows...." comment. Carry on.
    audioluvr Posts: 5,990
    wispolkboy wrote: »
    It means 13 k small children in china were involved in the build and assembly. You should y proud! Or scared...
    Edit. I mean Mexico
  • skrol
    skrol Posts: 3,464
    I am curious about the Monitor 5C. I am aware of the 5A, 5B and Monitor 5 Series 2, but not a 5C. If it is a 5A with Peerless tweeters, they are likely 12uF and 27uF capacitors. If it is a 5B then they are likely 12uF and 34uF. But you should look at your crossover components to get the values.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Skrol,
    Sorry if I gave you a wrong impression of having a peerless. It does not.
