Mincom 8300A-W Flutter Meter
skrol
So my dad found a 3M Mincom 8300A-W flutter meter and gave it to me about 20 years ago. It has been sitting in my basement and I decided to pull it out to play around with it. I cleaned the switches, pots and exterior. Problem is I don't have a manual for it and haven't been able to find one online. Anyone have info or a manual for this thing?
Stan
Main 2ch:
HT:
Other stuff:
Main 2ch:
HT:
Other stuff:
It appears to be the same device as the Ampex TU-40 Flutter meter, if you do a search for this there are a few articles that describe it's operation.
Sweet! I had a good feeling that you would have some knowledge of this thing.Stan
Main 2ch:
HT:
Other stuff:
No problem, it looks to be a really good meter.
Still haven't found an operations manual but I did stumble upon some public release articles on NSA's use of tape recorders. Very interesting stuff if you are into cryptologic and cold war history.Stan
Main 2ch:
HT:
Other stuff:
https://blogs.telosalliance.com/found-in-the-attic-ampex-tu-40-flutter-meter
This entry gives a pretty thorough description of its operation. -
Thanks Ken.
I guess the next thing I need is a 3,15KHz reference tape. I only have a BASF 1KHz / 12.5KHz tape.Stan
Main 2ch:
HT:
Other stuff:
For cassette or open reel?
What do you do with a flutter meter? I didn't know you could adjust flutter (and that Wow thing) in a tape deck.
KennethSwauger wrote: »For cassette or open reel?
Cassette. I could make a 3.15KHz recording using my Denon DRM-800A but it will have its own wow and flutter to compensate for.Stan
Main 2ch:
HT:
Other stuff:
That would be the way to do a record/playback w/f measurement, make the recording then rewind and play it back.
There's a guy on eBay who I can recommend highly, nielsfup2010 , his name is Niels and he lives in Denmark and he sells really good quality alignment tapes. It would be around $70.00 for a cassette tape including shipping. He uses good quality recording gear and has calibrated carefully.
Does the Mincom use 3.15kHz or 3.0kHz?
