Mincom 8300A-W Flutter Meter
So my dad found a 3M Mincom 8300A-W flutter meter and gave it to me about 20 years ago. It has been sitting in my basement and I decided to pull it out to play around with it. I cleaned the switches, pots and exterior. Problem is I don't have a manual for it and haven't been able to find one online. Anyone have info or a manual for this thing?
Stan
Main 2ch:
HT:
Other stuff:
    pitdogg2 Posts: 27,371
    edited December 2020
    @mhardy6647 @KennethSwauger
    On your marks get set ....GO!😉
  • [Deleted User]
    [Deleted User] Posts: 7,598
    It appears to be the same device as the Ampex TU-40 Flutter meter, if you do a search for this there are a few articles that describe it's operation.
  • skrol
    skrol Posts: 3,466
    Sweet! I had a good feeling that you would have some knowledge of this thing.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • No problem, it looks to be a really good meter.
  • skrol
    skrol Posts: 3,466
    Still haven't found an operations manual but I did stumble upon some public release articles on NSA's use of tape recorders. Very interesting stuff if you are into cryptologic and cold war history.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,466
    Thanks Ken.
    I guess the next thing I need is a 3,15KHz reference tape. I only have a BASF 1KHz / 12.5KHz tape.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • For cassette or open reel?
  • delkal
    delkal Posts: 764
    What do you do with a flutter meter? I didn't know you could adjust flutter (and that Wow thing) in a tape deck.
  • skrol
    skrol Posts: 3,466
    Cassette. I could make a 3.15KHz recording using my Denon DRM-800A but it will have its own wow and flutter to compensate for.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • That would be the way to do a record/playback w/f measurement, make the recording then rewind and play it back.
    There's a guy on eBay who I can recommend highly, nielsfup2010 , his name is Niels and he lives in Denmark and he sells really good quality alignment tapes. It would be around $70.00 for a cassette tape including shipping. He uses good quality recording gear and has calibrated carefully.
    Does the Mincom use 3.15kHz or 3.0kHz?
