Oldest non-serviced amplifier that you still use daily
I have a Carver 900 receiver (1985) I use in my barn system. Still sounds great.Gustard X26 Pro DAC
Ha ha !
Dang !
How about an untouched Yamaha R9 receiver I bought in ‘87 or ‘88 ?
Sitting in the closet , however ....
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
If it still works and plays, then yes!
Realistic STA 52 1976 model. Works great in the shop with Dynaco A-25's.
PS Audio 200CX 1989 model (I think) with Klipsch Quartet's. I do not use either one every day but when I am in the area of the house/shop they in they are on and still running fine. -
Looks like you have one too ....
Sweet little receiver , huh ?
BkIf it still works and plays, then yes!
My NAD C-370 integrated.
I guess 10+ years now pushing hard to drive speakers without a flinch.Most people just listen to music and watch movies. I EXPERIENCE them.
Bk
Just found on google image search but yeah I like the design. -
I have a krell ksa 300s amp I use every day.
Arcurus A100X3 that I use in HT. Probably around 20 years old.
I am listening to "holiday" music on this dump find Yamaha 5-channel A/V receiver (as a stereo) via a pair of Altec Santiagos as I type this. No work's been done on the Yamaha other than my cleaning the controls and switches after I determined that it did in fact work.
Rascal actually sounds pretty good; I've been using it and the Santiagos for Zoom meeting audio via one of those little Bluetooth receiver thingies.
I don't actually know how old it is though -- certainly not old by my standards for hifi.
The Santiagos are as new and date from ca. the early 1970s, if that counts for anything.
DSC_0368 (3) by Mark Hardy, on Flickr
That 2-channel R-9 or whichever "R" it is that was mentioned by @clipdat is considerably cooler, though.
You guys are gonna play "old stuff that works" with Hardy?
Yeah. Good luck with that.
Even Jesse would think twice. -
But, but, but -- as I said earlier... any of the old stuff I actually use, I maintain.
I doubt that any, umm, I hope that none of all y'all* are is** running 40, 50, or 60 year old hardware with original electrolytics in it (e.g.).
Electrolytics don't age gracefully -- 'specially the first stage AC mains filters
I will, if pressed, however, own up to not slavishly replacing all electrolytics in a component prophylactically! I don't muck with tuned circuits (i.e., radio sections of receivers or tuners) without danged good reason to -- and (truth be told) there are more than a few aged vacuum tube components here with original multisection can electrolytic capacitors still in 'em. If I "reform" them on first power up (as opposed to slammin' 'em with AC mains voltage) and if they run cool (i.e., empirically still seem to have low internal resistance), I have been known to justm umm...
_________________
* how's that for the Dark Side of English Grammar and Syntax?
** "none", of course, is a singular noun.
Most of my older non serviced, daily use amps are gone once I looked them as liabilities rather than assets. I did keep a couple 80's vintage Mcintosh amps but now they both have issues and need the 4 hour trip to Audio Classics; hopefully sometime this winter. So that leaves just my mc1201's from early 2000's. I'm really dreading the day they need servicing at 147lbs apiece.
I imagine the shipping cost would add significantly to the cost, especially having to ship two units at that weight.
No way would I trust them getting shipped. If or when the time does come it'll be a strong buddy and little old me wrestling them into my vehicle for the ride to Vestal NY.
I had forgotten my B&K Ref 4420 had been serviced by the previous owner.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
