Oldest non-serviced amplifier that you still use daily
Clipdat
Clipdat Posts: 12,560
What's your oldest un-serviced power amplifier that you still use daily/weekly?
Mine is my 21 year old Klipsch Promedia v.2-400 system that I'm still using to drive a pair of Polk Audio Blackstone TL3 speakers daily.
It stays on 24/7 since it doesn't even have a power switch and it's still working as flawlessly as the day I first plugged it in 21 years ago. I keep expecting it to die and it just won't!
  • Nightfall
    Nightfall Posts: 10,042
    edited December 2020
    Isn't the ProMedia a computer speaker setup?
    I don't know when it was released but I use and also keep on 24/7 my B&K Reference 4420
    I used to use my very old all original Yamaha CA-1010 but it did finally have a channel go out, I just have yet to pay someone to look at it.
    Does the original head unit in my 1995 Honda count? 😉. I use that more than anything really.
    afterburnt wrote: »
    Village Idiot of Club Polk
    Yep, it's a computer speaker setup.
    Also I should mention that I did have to replace the preamp control pod a few years ago. But I'm mainly thinking about the power amp section inside the subwoofer.
    And yeah the Honda HU counts!
  • Nightfall
    I remember when the ProMedias first came out, I was very big into PC gaming and they were THE PC speakers to own.
    afterburnt wrote: »
    Oh yeah, absolutely. The later generations had some cost-cutting measures, but I think this original v.2-400 model with the dual sub drivers were the best.
    I used it primarily with the Klipsch satellites, but let me tell you the TL3s sound a hell of a lot better!
  • afterburnt
    afterburnt Posts: 7,892
    An Emo 3 channel it ain't too old but it's the oldest amp that I still use.
    pitdogg2 Posts: 24,481
    Aragon 8008bb
    Tax time and I'm getting this one completely gone through and recapped. Still works fine but it's long in the tooth.
    Nice, Ivan.
    I was wondering if mine is starting to drift out of spec as well. I'm so accustomed to its amplification quality that it's hard to determine if upgrading would improve things.
    I suppose its possible that its starting to have issues but I haven't heard anything audible.
    Well IME you will never know the gradual decline unless a pre-driver, transistor or cap goes bad. The usual suspects is a buzz, static or low output on one side.
    I plan on this being with me for a decade or longer so I'll spend the cash.
  • I really like the "notch" in the Aragon amps. Different!!
    Harry / Marietta GA
  • Emlyn
    Emlyn Posts: 4,346
    I have a Classe Model Twenty Five I picked up from TroyD years ago. Not sure exactly when it was produced and I can't bother to look because I know generally what the production years were, but I suspect it is around Twenty Five years old.
    It took a Parasound JC5 to displace it in my main rack. Still works great though.
  • rooftop59
    rooftop59 Posts: 7,952
    My musical fidelity a308 that has made the rounds here on club Polk was manufactured around 2001. Its normally in 24/7 though I do shut it off overnight when I think about it. I know @Ricardo kept it on 24/7. It is by far the best sounding integrated I’ve ever owned. It supplanted the Cambridge 851a which I really liked...I don’t see it going anywhere any time soon, so I hope the caps hold up cause I’m in a small market and have no soldering skills lol...
    Game Room 5.1.4:
    Bedroom 2.1
  • Ricardo
    Ricardo Posts: 10,636
    rooftop59 wrote: »
    Glad you're enjoying the A308. Soldering is not difficult really. I'm sure you can do it with a little practice ;)
    SOPA
    Soldering is the easy part, re-biasing and other stuff is where knowledge and scopes come into play...
  • 1971? Crown D150 :# Sounds great however it has recently developed an intermittent issue in the left channel where it becomes very low level slightly distorted sound. It's unmistakable when it happens. The simple cure is to pull the Right channel input and then disconnect and reconnect the Left. That always cures it instantly. Interestingly, unplugging the Left and re-plugging does not cure it unless the Right is first unplugged. Seems like a transistor issue but I really have no clue why it behaves this way.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • invalid
    invalid Posts: 1,271
    I thought you could just put your hand on the heat sinks for 10 seconds, then your amp was biased correctly. Old nelson pass trick.
    tonyb Posts: 32,903
    Old B&k 4420........not sure the year but guessing close to 20 years old.
  • DaveHo
    DaveHo Posts: 3,471
    I have an Adcom GFA-555 in the bedroom rig. I'm not the original owner, but I'm pretty sure it hasn't been serviced. I pull it every once and awhile to check the DC offset. Still within acceptable limits.
    invalid wrote: »
    I'll take Nelson's word if that is how he does it! That guy passes more knowledge in gas than I'll ever have upstairs!
  • tratliff
    tratliff Posts: 1,651
    My dad has a Denon POA-2200, also a Denon pre and integrated from the same era, that is still going strong. I am not sure of the exact age but it dates back to the early to mid 80's.
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, AudioQuest Thunderbird Speaker and Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
  • Milito
    Milito Posts: 1,908
    tonyb wrote: »
    Same here.
    Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables.
  • maxward
    maxward Posts: 1,491
    A mid-1980s Superphon DM-220 is still going strong. However, it was recapped because it seemed like a good idea 5 or 6 years ago.
  • BlueFox
    BlueFox Posts: 15,251
    All my old speakers have been given away. Since I am now retired, the odds are my current stereo and HT speakers will be old in 20 years. :)
  • decal
    decal Posts: 3,205
    Adcom GFA 535 since 1988, has never missed a beat.
  • BlueFox
    BlueFox wrote: »
    Oops. This also applies to the amps. Sorry. :)
    mhardy6647 Posts: 32,929
    The old ones here have all been serviced - even if only cleaning pots and switches, or changing tubes and/or electrolytic capacitors, setting bias points, etc.
    Now, those old ones are, in some cases, older than I (maybe even older than @F1nut! ;) ), but they have been maintained.
  • Gerres26
    Gerres26 Posts: 859
    invalid wrote: »
    This is at least somewhat true...when I was re-biasing my X250 and looking for advice, Mr Pass actually chimed in and was definitely more worried about heat sink temp than actual voltage measurements across resistors...and yea he recommended the 10 second hand rule which was supposed to be about 50 degrees C if I remember correctly.
  • Gerres26
    Gerres26 Posts: 859
    And that Pass X250 is one amp I wish I would have kept, but curiosity got the best of me and I let it go :'(
  • gyosa
    gyosa Posts: 675
    I have a B&K EX-442 I bought new 1989 or so , with the toshiba outputs , 75 amps current vs 50 for the hitachi outputs ( Sonata version - before they called it a Sonata).
    Untouched other than a few new power switches over the years ( bought a bunch of spares ) and had the offset and bias adjusted a couple years ago ....
    Still running like a champ !
    Does that count ?
    Bk
    Parasound A21 , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Yamaha wxc-50 , Boston Acoustic voyager 7’s - POOL
    PS Audio Stellar S300 , Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
    Cambridge Audio 851n - sitting in the closet , for now
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
    DAYENS AMPINO ( thanks Verb ! ) , KEiiD streamer ( this was only 60 bucks ?? ) , Polk atrium 8SDi’s - KID’s BEDROOM
    gyosa wrote: »
    Does that count ?
    Nope. But thanks for playing! :p
  • TroyD
    TroyD Posts: 13,077
    Emlyn wrote: »
    Holy crap. That was a minute ago!
    ( if you ever want to sell it back....that was a great amp!)
