Headphone Amp advise needed.
I am looking for a headphone amp to use with my existing preamp. Currently using a Hafler DH110, which has been re-capped, so I do not want to eliminate it. I was looking at the Schiit Vali 2+. I am not sure how it should be hooked up. I do not want to plug my TT directly into it, so how would I do the hookup? The headphone jack on my Hafler sounds fine, but I am looking for more volume. My headphones are the AKG Q701’s which are 62 ohms. Will the Vali 2+ work? I like the idea that it is a tube amp. Does anyone recommend a headphones only amp with 1/4 “ banana jack that I could plug into my Haflers Headphone jack and then plug the headphones into the headphone amp?
Hafler DH220 Power amp Recapped
Hafler DH110 Preamp Recapped
Hafler Digital FM Tuner
Virtue Audio M1 Piano CD Player
Technics SL-1210-MK5 with a Rega Exact Cartridge
Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
    Clipdat Posts: 9,820
    gdphoto wrote: »
    Do not do this.
    gdphoto wrote: »
    Use one of the preamp's RCA outputs into the headphone amp's input. I think you are really overthinking this.
  • gdphoto
    gdphoto Posts: 164
    Could you explain why I shouldn't do this?
    Because that's not how you hook up a headphone amp.
    edited December 2020
    Edit: I'm dumb
  • gdphoto
    gdphoto Posts: 164
    I am still a bit confused. If I hook it up to the AUX or Tape Out and I want to listen to my TT it will work? The selector switch will be set on Phono and not the others. Sorry! I never had to do this before.
    Actually, I'm stupid. What you want for this use case is a fixed line level output that is not behind the master volume control, because you want the full un-attenuated signal going to the headphone amp, since the headphone amp has it's own volume control.
    Here's a link to the manual you can see the output options and which one would work: https://www.manualslib.com/products/Hafler-Dh-110-227426.html
  • gdphoto
    gdphoto Posts: 164
    Ah! I never thought of that. It would be like I have 2 TT's hooked up. I would just switch over when I want to use the headphones. I didn't see your detailed post before I sent my last one.Thanks!
    Ideally the tape out or effects loop out would be a fixed level, not behind the master volume control attenuation.
    Maybe someone else can chime in here. I'm going for a walk now.
  • gdphoto
    gdphoto Posts: 164
    It sounds like Tape Out would be the easiest hook up. Does anyone have a recamendation on a headphone amp? I see there are some tube types that are reasonable. Would a tube amp sound better than solid state. Or, it doesn't matter because my Hafler is solid state.
    Post edited by gdphoto on
  • gdphoto
    gdphoto Posts: 164
    I won't use it often, so I would like to stay in the $150 range.
  • gdphoto
    gdphoto Posts: 164
    If tubes don't matter, I found this on amazon For $79. Schiit Magni 3 Headphone Amp and Preamp. However, if tubes make a positive difference I'll spend more. I have no experience with tube amps.
  • gdphoto
    gdphoto Posts: 164
    By the way, I never would have thought about the Tape out option.
    I think the small formfactor Schiit headphone amplifiers are well-liked, but I only have experience with their Asgard 2 headphone amp.
    Since you are still shopping, take a look at Toppings offerings as well, they are really nailing the price to performance ratio: https://www.amazon.com/Topping-L30-Headphone-Amplifier-Preamplifier/dp/B08DXRQ4R7
  • George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • gdphoto
    gdphoto Posts: 164
    Still not sure about the tube amps. Do they sound better?
  • Check this one. It puts out 2.2W at 62ohms and Toppings get good reviews.
    https://drop.com/buy/topping-a50-headphone-amp
    I have the Schiit Jotunheim and I love it.
    Cheers
    HT
    AVR-Pioneer SC99
    Adcom 585
    RTi12s
    Rear- RT150
    Center-CSi5
    Sub-Rythmik audio F25
    Player- Oppo BDP-103
    Living room 2ch rig:
    Peach Tree Decco, Onkyo CS-5VL SACD and Linn Kelidh
    Bedroom 2ch rig.
    Cary AE-3, Parasound 2125, Marantz SA8005, Usher V-601 or SDA 1C, SVS SB12-NSD, Intel NUC PC and Panamax MX5105
    Headphone rig;
    Little DOT MK II with upgraded tube's and Sennheisers HD650.
  • I got lucky and have a Singlepower PTP wired tubed headphone amp,, short of a dedicated head amp, the audible illusions L 1 pre has a killer headphone section.Just my .02 Good luck
  • gdphoto
    gdphoto Posts: 164
    I ordered the Schiit Hersey. I'll let you all know how I like it. Thanks for all of the great input!
    EndersShadow Posts: 17,234
    Try the “Can Opener”....
    It taps into your existing speaker outputs....
    https://vinylflat.com/canopener.html
  • ALL212
    ALL212 Posts: 1,333
    Similar in function to the CanOpener. I've used this on my Bottlehead Stereomour modified to use 45 tubes. That amp wasn't designed to work with headphones and has just a smidge of hum when you do so but it's hard to find a cheaper adapter!
    Aaron
    Enabler Extraordinaire
