Have a polk command bar remote doesn't work at all after changing battery's
I've done a factory reset on the command bar no luck. Anything else I can try
Answers
  • regan
    regan Posts: 3
    I've also tried ir learning mode but no results
  • [Deleted User]
    Send an email to: kim.jasper@soundunited.com and explain what is happening.
  • kthilmany
    change my battery in the Polk remote Soundsystem controller and now it doesn’t work. It worked for a while, but now it doesn’t work.
    F1nut Posts: 52,406
    Maybe try some better batteries
    treitz3 Posts: 20,366
    Not saying this is your particular issue, but take a serious look at the connector points where the batteries make contact. There may be acid, debris or oxidation that blocks the voltage that operates it.
