Have a polk command bar remote doesn't work at all after changing battery's
I've done a factory reset on the command bar no luck. Anything else I can try
Answers
I've also tried ir learning mode but no results
Send an email to: kim.jasper@soundunited.com and explain what is happening.
change my battery in the Polk remote Soundsystem controller and now it doesn’t work. It worked for a while, but now it doesn’t work.
Maybe try some better batteries
Not saying this is your particular issue, but take a serious look at the connector points where the batteries make contact. There may be acid, debris or oxidation that blocks the voltage that operates it.
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
