SDA 2B 1987 studio version
Cylontymany
I believe this is what I have since they have the dark wood and cloth wrap around grills. Would like advise on restoring these. Are mine able to implement the TL mod to incorporate the RDO-198 tweeters? Thanks
If you have the ones with the wood caps (top and bottom) and cloth wrap around grills with cloth wrapped sides, they're not the studio version. If they have the pin/blade interconnect cable rather than the blade/blade, then they can be TL modded with the RD0198 tweeters.
Get some input from others around here that have modded countless pairs - @westmassguy or @VR3. -
The CRS+ SL3000 modification also applies to your 2Bs:
https://us.v-cdn.net/5021930/uploads/attachments/1/8/5/1/1/26710.pdfHome Theater/2 Channel:
dhsspeakerservice.com/ -
Interesting! So what model due I have then? I have the small and large blade cable. I want to eventually send out the crossovers for recapping and Mod if I can depending what I have?
If you have cloth on front and both sides they are 2b. I had a pair with the blade/blade interconnect but they were the single board crossovers that can be tl’d.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
If you have a slab wood top, wrap around grill, single tweeter, with a blade/blade interconnect, your model is a transitional 2B. Polk used up the leftover parts when transitioning from one generation to the next.Home Theater/2 Channel:
Check drivers
Sda2b will have 1-6503 and 1-6511
Sda2a will have 2-6510 drivers
http://www.gimpod.com/sda-id.html -
Mine are exactly the same. B/B single corssover board and I can confirm that they definitely can be TL'd.dkfreebird wrote: »If you have cloth on front and both sides they are 2b. I had a pair with the blade/blade interconnect but they were the single board crossovers that can be tl’d.
^This.westmassguy wrote: »If you have a slab wood top, wrap around grill, single tweeter, with a blade/blade interconnect, your model is a transitional 2B. Polk used up the leftover parts when transitioning from one generation to the next.
SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
