Brian made some plates and then powder coated them. all I had to do was knock a bit of the powder coating off and press in. It's tight but not unbearably tight. Good and snug I'd say.
So is the 1.22" ID Correct for the one you sent?
Also 1.150 on square will be taps. Did you use 6-32 bolts. Thats what I tapped the NL2's for.
There is another "NL4" drawing that has same ID as the NL2 plates I made. Thats the hang up. I'm in shop today and want to get these knocked out.
The NL2 socket can be retro-fitted with these larger Dia. NLT4 sockets, so I'm modding a set and working on the patina to match all the billet RD0 tweeter plates.... I'm using a Scotch Brite pad at 290rpm.... Hits the spot...
"No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
A d connector and a g connector.
The g connector is wider, its an all metal chassis.
The d connector matches the nl2, plastic nl4, xlr jacks, etc
And yes 1.22 is correct
Hope Ace Ventura didn't get ahold of the package lol
Gotcha I didn't realize that.
