Just got these RTA 12B’s.
  • Harv2002
    I’ll have to go see if I can find some locally. This is the smallest kind I have.
    John
  • Harv2002
    Again with the sideways picture. I don’t know why it does that.
    John
    Tony M Posts: 11,964
    Harv2002 wrote: »
    John
    When you take a pic, your position of the device taking a photo determines either portrait or landscape.
    I don't know about smart phone pics. but when I download my pics to my PC, the pics appear according to how I held my camera. Portraits will almost always have to be turned after putting them into a program to store them.
    NOW...after downloading ( or up-loading ? ) I click on a picture to look at it. A few choices appear ON TOP of the picture after a couple of seconds. One choice is to turn the pic. 90 degrees to the right. You can keep turning the pic as many times as you desire. It can then be positioned the way you want to view it later on.
    Smart phones pic. orientation adjustment...somebody else will have to opine.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    edited October 2020
    I know a local cat that has a minty set of these but he wants 500 for them probably not a bad price ??
  • Harv2002
    So. This is for each crossover so X2.
    4-2uf electrolytic
    2-4.4uf mylar
    1-55uf electrolytic (combo of 2)
    7.5ohm Resistor on the bottom.
    Clarity? Sonicap?
    Mills for the resistor I guess.
    What am I missing?
    John
  • CH46E
    CH46E Posts: 3,595
    edited October 2020
    Harv2002 wrote: »
    4-2uf electrolytic
    2-4.4uf mylar
    Clarity? Sonicap?
    What am I missing?
    John
    You mean 27uf x4 for each crossover.
  • CH46E
    CH46E Posts: 3,595
    edited October 2020
    This is what I used.
    8 27uf Jantzen CrossCaps
    4 4.4uf Sonicaps
    2 56uf Mundorf Aluminium Evo cap
    2 7.5 ohm Mills.
    I removed the small silver myca bypass caps.
    These crosso er boards are very easy to solder on.
  • Harv2002
    CH46E wrote: »
    Yes, I did indeed.
    John
  • Harv2002
    Thanks so much for the list.
    John
  • CH46E
    CH46E Posts: 3,595
    Later on another project I found out about solder wick. Made desoldering the old parts so so much easier as well as removing the old solder. Worked much better than my solder sucker.
  • Harv2002
    Are the Dayton Audio caps the same as Sonicaps? If you search parts express that’s what comes up.
    John
  • CH46E
    CH46E Posts: 3,595
    edited October 2020
    I'm pretty sure they are not. Only place for Sonicaps is thier own website.
    "Sonicap Capacitors, Sonic Craft" http://www.soniccraft.com/index.php/film-capacitors-sonicap-c-301_49
  • Harv2002
    CH46E wrote: »
    4 4.4uf Sonicaps
    2 7.5 ohm Mills.
    On the Mills resistors, 5, 10, or 12 watt?
    John
  • Harv2002
    Harv2002 Posts: 56
    edited October 2020
    Wait not 47.
    John
  • CH46E
    CH46E Posts: 3,595
    I'm pretty sure I went 10 watt. Id go 10 or 12. Either should be fine.
    FYI that 56uf Mundorf is huge.
  • CH46E
    CH46E Posts: 3,595
    Harv2002 wrote: »
    John
    I would not go electrolytic. All film 100%.
  • CH46E
    CH46E Posts: 3,595
    But those are good electrolytics. I used them on my Infinities that needed a 1,600 uf vale and 600 uf value. Film in those values would have been astronomical in price.
  • CH46E
    CH46E Posts: 3,595
    The Jantzen CrossCaps are very affordable and available in large values.
  • Harv2002
    Ordered them up!
    Thanks for the pic of the Mundorf.
    John
    F1nut Posts: 52,301
    edited October 2020
    Hell no Dayton caps are not Sonicap caps. Dayton and Bennic are the same though, you don't want either.
    xschop Posts: 5,742
    Daytons= more $ for better amp lol.
    pitdogg2 Posts: 27,775
    edited October 2020
    Harv2002 wrote: »
    John
    No!
    I'd go low Clarity before the dayton audio
    Dayton audio is made by bennic IIRC.
  • Harv2002
    Good advise. I got the Sonicaps.
    John
  • CH46E
    CH46E Posts: 3,595
    edited October 2020
    All Sonicaps? Do tell what ya got?
    Post edited by CH46E on
  • Harv2002
    CH46E wrote: »
    4 4.4uf Sonicaps
    2 7.5 ohm Mills.
    This is what I ordered.
    John
  • Gardenstater
    Gardenstater Posts: 4,885
    You'll save a lot of money over what my example above came out to, hopefully with not very much less performance. Those Jantzen and Mundorf caps have fairly decent ratings compared to Sonicap and Clarity CSA. http://www.humblehomemadehifi.com/Cap.html
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,742
    Ducati makes caps?
  • CH46E
    CH46E Posts: 3,595
    No matter how you slice it, they are a huge improvement over 30 year old electrolytics.
    You will very much enjoy the 12b.
  • CH46E
    CH46E Posts: 3,595
    edited October 2020
    As you can see in my photo above, I had to make some leads so I could relocate that pop can of a cap to the middle.
  • Harv2002
    xschop wrote: »
    Ducati makes caps?
    Yes but they are attached to a gas tank that feeds 90° Of Desmodronic bliss. If I was really a motorcycle guy, I’d have one just to listen to it!
    John
