Question on Definitive Technology BP8080ST
A buddy of mine has a pair of BP8080ST's and he thinks one of the plate amps is bad. Any of you DT fans - what are his options? New plate amp? Are the speakers worth it? Is this a known issue with this speaker? Anybody got a spare plate amp for this model in the closet? Thanks for any help.
Definitive should still stock these since it is a last year model, should be around 100 to 200 i would guess- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks fellas. That’s not bad.
Common issue with Powered towers and Subwoofer for that matter. I really dig the 8080 line, I've installed them many times and always walked away proud and happyDan
