Custom tube amps but "unknown" manufacturer.
delkal
This is a Craigslist ad that always caught my eye. There is a guy making custom tube amps for more than reasonable prices but I can not find anything about him on the net. All I can find is his name is Nikola Nikolov and he has a gallery of sweet looking amps. And from looking at his Craigslist listing it seems he can make custom amps out of any tube imaginable.
Anyone heard of him?
Craigslist ad
https://philadelphia.craigslist.org/ele/d/baltimore-new-prices-6-audiophill-tube/7207791780.html
Gallery (nice looking but what is inside?)
https://photos.google.com/share/AF1QipOYq0r3yyYjkhz179q5evuYNSCotX8Bl0oG5exYcM-KRBbhIGjGYMWFBLMSx-YDcw?key=NS1PRC1mR1o2cGx4MWNJMmZySzBRRE9nREVjZDB3
Craigslist ad
I would look into the quality of those "Edcor" transformers, as the quality of the transformer is arguably one of the most important things when considering a tube amplifier.
Edit: Looks like their transformers are made in the USA. That's a good start. -
The Edcor transformers are good quality, "value priced" transformers. Far from the best available, but very respectable.
I dunno, the amps themselves look like a total hodgepodge. They look OK, and the asking prices don't look outrageous, though.
I'd definitely see if you can negotiate a pair of the pyramids, though.
If He's local and you're serious have him bring over a half dozen for you to demo in your environment.Gustard X26 Pro DAC
He is about 2 1/2 hours away so it starts to be a long drive just to demo something. I will have to email him one day and ask for more info on his designs and what he can make.
It would be a good idea to ask if he supplies a schematic drawing with the amps. That way any future repairs could be done easier.
KennethSwauger wrote: »It would be a good idea to ask if he supplies a schematic drawing with the amps. That way any future repairs could be done easier.
Good idea, but A lot of designers don't like to give out schematics, so nobody can copy their designs, but maybe a small company would. -
I suspect those amplifiers are pretty simple designs.
If they're point to point wired, they likely wouldn't be too difficult to trace out even sans a schematic.
mhardy6647 wrote: »I suspect those amplifiers are pretty simple designs.
You are correct, I think any competent tech could figure it out. -
The nice thing about a well done schematic is that there will be operational voltages listed and details about changing taps on transformers for different line voltages. Also part values (in case something ends up unreadable on the part itself) and how the circuit's feedback loop includes the output transformer's taps. It's kind of like I know the general location of Denver from Maryland and if I drive west long enough I'll find it. But having a nice map would be helpful.
Simple is what I want this time and they are point to point wired. I would like to try a classic old school tube amp without all of the modern bells /whistles and exotic circuitry. I understand that modern designs can "sound better" and be more accurate but I am looking for the classic warm tube sound even if it also shows some of the tube limitations.
I did search for some schematics for an SET amp with some of the tubes he uses and there are many (hopefully already worked out) on the net. I am hoping with a simple circuit like this the sound quality will be more dependent on construction and quality of parts than small tweaks. But maybe that is just wishful thinking............. -
... or any competent and sufficiently motivated owner, I'd opine.
You want a good, simple, excellent sounding vacuum tube amplifier? If you can handle the (low) output power, get that guy, or someone else, to build you one of these -- or just grit your teeth and do it yourself. I am still completely and thoroughly pleased with the one here.
Use (or specify) the best quality output iron you can afford for it, while you're at it.
http://jelabsarch.blogspot.com/2012/06/je-labs-simple-452a3.html
DSC_4262 (2) by Mark Hardy, on Flickr
Nice build, I like point to point wired tube gear.
Aside from how good that must sound, it just looks gorgeous Mark.
No complaints.
Hi, my name is Nikola Nikolov "Unknown" manufacturer. Im glad to participate in this forum.
Forgot your spam link genius... -
"My name is Inigo Montoya. You killed my father. Prepare to die."2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
this is getting interesting
I like Single Ended tube amps and like experiment with different old tubes. Next amp will be SE with 50C6. I like also direct connected full range speakers to the outputs, without crossovers, that press sound and decrease it quality. My speakers are mod. Jensen with changed bass to 12" full range Electro Voice - from 30 to 13 000Hz and tweeter Jensen for 18-20 kHz.
The amp above with pyramids is SE 2A3 RCA & E180F Phillips, on of the best my amps. Pyramids are against "black Magic". Also one of the best is SE EL11 Telefunken with output transformers without saturation, that is my decision.
txcoastal1 wrote: »
When it was?
You don't recognize my face? Let me remind you
https://youtu.be/6JGp7Meg42U 2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Excuse my jest, as we like many other forums acquire spam. Very interesting and appreciate you chiming in...welcome!!
"We" (ahem, OK I) misjudged you, it appears, @azazello.
My apologies!
EDIT: Oh, jeez! I finally get it! Yes, the builder of the amps in the OP!
I am so sorry!
I am perplexed, though, by this statement:
Pyramids? What pyramids? and what sort of black magic are you running afoul of?
Which EV fullrangers are you using in your "modified Jensens"? MC12, LS12/LS12A, SP12B, SP12, or other?
mhardy6647 wrote: »"We" (ahem, OK I) misjudged you, it appears, @azazello.
My apologies!
I am so sorry!
Pyramids against evil ears and eyes......I used EV SP12B, it was hard to find 10 ohms speakers. The sound is very pleasant and my friend in Baltimore very like them. -
Thanks for your interest in first posts above. .....One my amp SE 6BQ6 RCA with sound very close to SE 2A3 RCA
Rega Planar 8, Apheta 3 MC , Aria mk2 Phono
Aurender n100h, Benchmark DAC2 HGC
Arcam SR250, Parasound JC5
Revel F208, SVS SB-4000
