Stuck Screws
I'm retired. Go to at least 50 shows a year. I'm bored. Let's get out the deck that's been boxed in a closet for 20 years (bought new in 1975).5p5fupfemlen.jpg
Oiled it up. Plays and sounds great. However, the pinch roller needs to be pushed into place. Common problem with this deck. Found a detailed video for the fix. First step is to remove this bracket tzg215pdk8y2.jpg
There is some green stuff around the screws and these suckers ain't moving. Any tips (actone and heat from a soldering iron were no help).
SDA 2BTL, VPI Prime, Soundsmith Zephyr MKIII, Rogue Ares Magnum, McCormack DNA 0.5 Gold, ARC LS-17se, Cambridge cxn v2, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
    VR3 Posts: 28,020
    The internet says green loctite and heat should do the trick
  • jonicont
    VR3 wrote: »
    What do you think would be the best way to apply the heat?. Maybe I didn't keep the soldering iron on long enough
    pitdogg2 Posts: 24,556
    jonicont wrote: »
    VR3 wrote: »
    or hot enough, what is your top temp?
  • jonicont
    450c--842f
  • jdjohn
    jdjohn Posts: 3,000
    I'd think a nice, wide chisel tip is what you want to use in order to get the best heat dissipation.
  • Jazzhead
    When I was a ski technician I often had to carefully remove screws in expensive bindings that had been epoxied in place. I would hold a long-shafted screwdriver in the top of the frozen screw and apply heat to the lower part of the screwdriver shaft with a mini torch. This would allow the heat to conduct into the screw head in a somewhat controlled fashion. I don't know about doing this inside a tape deck... sounds risky. But it worked with skis when nothing else would.
    Polk Audio first generation RTA-12s; 12 inch Polk Stands; DHS Speaker Service upgraded crossovers w/ Sonicap/Mills; the "westmassguy anti-lobing mod" (hyperdamped outer drivers/mirror imaged); tweeter anti-diffraction mod; Cardas binding posts; Neotech UPOCC internal wire; foam-lined inner driver baskets; xschop phase plugs; deleted fuses; Hurricane nuts; Sonic Barrier; Dynamat Xtreme
    Ayre K-5xeMP preamplifier
    Cambridge Audio 840C CD player; Herbie's Audio Lab Super Black Hole CD Mat
    D-Sonic Custom Audio M3a-600M monoblock amplifiers
    NAD 4155 FM/AM tuner
    Silnote Audio Morpheus Reference II Series II balanced interconnects; Virtue Audio single-ended interconnects
    Kimber 12TC speaker cable w/Furez connectors; VH Audio Flavor 4 power cables w/Furutech connectors
    Herbie's Audio Lab system isolation: Tenderfeet, Big Fat Dots, Grungebuster Dots, Little Fat Gliders
    Dedicated 20A/10 AWG circuit; Furutech GTX-D (G) outlet; Furutech eTP80; Shunyata Research Venom Defender; Synergistic Research Orange fuses
    mhardy6647 Posts: 33,029
    You're gonna laugh.. but did you try a 1/4 inch hex drive impact screwdriver? I've been amazed at the power and grace with which the one I have (a Milwaukee) works. I never strip out screw heads anymore.
    That TEAC is a surpisingly nice deck. An old friend of ours gave me his, from his college days. It has the same "issue" but it sounds really, really good with no restoration. I loaned it to a hifi colleague who uses it regularly.
    16185175652_e79b692487_b.jpgDSC_9928 by Mark Hardy, on Flickr
    edited September 2020
    Agree Doc I love mine. I wouldn't of thought about on this as it's kind of delicate item that teac.
    Post edited by pitdogg2 on
  • jonicont
    jonicont Posts: 277
    Well thanks. My son in law brought over an impact driver and a heat gun with a focusing nozzle. But it may be best to just keep manually moving it
    edited October 2020
    well, the other time-honored trick, with a good-fitting screwdriver, is to give the driver a few firm but careful taps (OK...whacks) with a small hammer to loosen things up.
    It might (????) be worth mentioning the difference between US "philips" head screws & driver bits vs. the JIS standard cross-point drivers and screw heads? I read on the internet (so it must be true!) that the path to enlightenment and fulfillment in working on Japanese electronics includes a set of JIS crosspoint screwdrivers. :)
    Nope, I don't have any. :)
    I am still pretty much a Neanderthal-grade tool user. Maybe even Austalopithecus-grade. :|
    https://www.vesseltools.com/handtools/screwdrivers/jis-japanese-industrial-standard
