Hafler 500 Upgrade
Sweet, some serious capacitance going on there. That thing is going to be a beast once you are done.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Got the board, rectifiers and components for the power supply upgrade.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I installed the ps upgrade last night.
Removed caps, rectifier and installed standoffs.
Board populated and tracks filled with solder.
PS installed.
Fired it up with a variac and checked the ps output voltage, all good. Installed the driver board fuses and checked the bias, all good less than 5mv.
Put back in the rack and fired it up.
I am impressed. No noise, very musical and rock solid but very delicate at the same time. These modern capacitors are quite amazing. Definitely more tactile bass while cymbals slowly decay and recording room ambiance is enhanced. I could not be happier.
I had goosebumps with body rushes.....
I am out of town for the weekend and can't wait to get back and listen some more.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
a side benefit to doing PS upgrades* in the XL 280s & 600s is they come from Hafler w/separate rectifiers & cap banks for each channel making the aforementioned* easier.motorhead43026 wrote: »Thanks, I really want to get the XL600 freshened up. I love these big Haflers.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
To the OP: did MC provide the wire to connect to the binding posts or did you reuse? In my XL280 I found subtle & not-so-subtle improvements using better/heavier wire for the above & PS caps to driver boards.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
I replaced the wire B-B+ from the ps to the driver boards but not the wire from the driver boards to the speaker posts.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I got 150 hours on the PS upgrade.
It's really really good.
Smooth as silk.....Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Just hit 300 hours.
Really opened up with a powerful bottom end. Wrap-around 3d soundstage. I did not expect this upgrade to have such a positive impact on SQ. I am pleasantly surprised.
Do these 2.3TL's have a limit !?
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I replaced all of the wire running from the power supply to the driver boards and from the driver boards to the binding posts with 12 awg. Also, I replaced the 35 year old thermal paste under the MOFETs.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
What type of thermal paste did you go with?
https://www.parts-express.com/nte-303-silicone-thermal-heat-sink-compound-1g-tube-5-pcs--nte303Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Well, after rewiring the power supply to driver boards, driver boards to speaker posts and replacing the thermal paste under the MOSFETS the amps mojo fell off. I had an oops o-carp moment. :'(
250 hours later the mojo is back in spades. It took that long for everything to settle and burn in!
It is sounding great
1KVA Dreadnought
Marantz SA 8005
Sony PS4
What wire did you go with?Gustard X26 Pro DAC
What wire did you go with?[/quote]
I got it through Musical Concepts.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Hello, any further updates or impressions? Anything you would differently? btw : where did you purchase the oslo power switch, is it lighted?
Thanks!! -
I've had a lot of fun and learned a lot upgrading the Hafler. Very little original except the chassis and mosfets.
I would not change a thing but I would like to try Musical Concepts new PA7 frontend someday.
Got the HD lighted switch from Musical Concepts.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Just upgraded my speakers to Acoustat 1+1s , My Musical Design D75 dies, and I'm digging out my old DH500. Had purchased many years ago PA-3b boards and dual mono transformers. Going to use the PA-3B boards , transformers, and update to the most recent MC dual mono board and Mundorf 15,000 Caps. Anxious for the parts to arrive to get started. Ordered Mundorf 1500 caps for the on board PS for the PA-3B, will have the Mundorf and a set of Blackgates for the other caps on board. Will run these for a while until I can upgrade again to PA-7s.
The power supply is a definite upgrade. I think you will be pleased. I also added an IEC socket and upgraded the power cord.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Have mogami wire to construct power cable, along with Connex Power/IEC Plugs Rhodium-Plated Copper , along with IEC rhodium /copper receptacle.
Machone... I have recently purchased a working DH500, planning the exact upgrades you have done. How is documentation/ instructions from John? I have experience rebuilding, upgrading Dynaco ST400, with success, pretty sure I can follow good set of instruction.
Did you have any issues getting responses to questions? Not familiar with filling solder tracks, is this a hot plate or oven procedure?
Thx... -
Excellent instructions and support. John knows Hafler. I used a soldering iron to heat and fill the tracks with solder.
Have fun!Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Thank you!
