Opinion on a turntable: VPI
Question for the hive, any opinions on VPI? And the unipivot arm?
Looking for my first table.
Thx
  • Upstatemax
    Upstatemax Posts: 2,842
    Not sure if Neil is still on the forum, but he loved his VPI table.
    @nspindel
  • joecoulson
    joecoulson Posts: 4,943
    The older VPI Scout is a table on my short list of Iwannabuy
  • hochpt21
    hochpt21 Posts: 5,423
    Going from a Pro-Ject 2.9 to a VPI Scout 1.1 was pretty significant. Granted, I have a Grado Gold on the Project and an Ortofon 2m Blue on the VPI, but nonetheless it was another level of sound.
    The unipivot is unsettling at first (and still a bit now), but I found it fairly straightforward to set up.
    Even my entry level Scout feels extremely solid and quality-built. VPI brand has a certain air of respect with a pretty large following. Also a huge range of tables to suit your budget and needs.
  • tratliff
    tratliff Posts: 1,825
    The VPI tables are awesome. I have a prime and have had it for about 4 years. It has the Unipivot. It is a little strange in how it works but it does a fantastic job.
    What table are you considering? Cartridge? Phono pre?
  • Mike Reeter
    I've had a VPI Classic for around seven years now. One of the pieces I don't think about upgrading.
    The Uni-pivot does take some time to get accustomed to, but when properly set up, it just sets there and glides through the grooves effortlessly, perfectly balanced.
    VPI offers a Gimbal Tonearm that would probably be a little less frustrating for a Vinyl newcomer.
    https://www.google.com/url?sa=i&url=https://upscaleaudio.com/products/vpi-hw-40-anniversary-direct-drive-turntable&psig=AOvVaw2Xclre0DWOkw-VAQii_Ocv&ust=1601077520387000&source=images&cd=vfe&ved=0CAIQjRxqFwoTCLiR9Pf8guwCFQAAAAAdAAAAABADrlbdwfytdmkx.png
  • maxward
    maxward Posts: 1,729
    I’ve had my Thorens for 47 years. If I ever replaced it, I would only consider VPI, especially after reading what they did for local medical personnel during the pandemic. No personal experience with one in my system, however.
  • vmaxer
    vmaxer Posts: 5,121
    Ouch
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    mhardy6647 Posts: 35,418
    The unipivot arms do take some getting used to -- I like the VPI tables I've experienced (and I am OK with the arms). Not really my cup of tea, but certainly not junk, either.
  • teekay0007
    teekay0007 Posts: 2,288
    Clipdat wrote: »
    That thing doesn't even have a 78 RPM setting....pass.
  • Joey_V
    Joey_V Posts: 8,603
    edited September 2020
    tratliff wrote: »
    Is the unipivot a pain to maintain? I worry about center image solidity.
    The table:
    VPI Avenger Reference with fatboy, rim drive, peripheral ring, center clamp
    The cartridge:
    Lyra Etna
    Phono:
    Not sure yet, probably ARC Ref 2 or higher
  • Joey_V
    Joey_V Posts: 8,603
    Clipdat wrote: »
    Serious question
    How would this compare to the Avenger Reference?
  • jdjohn
    jdjohn Posts: 3,416
    Oh my...another rabbit hole. But I must say, Joey, you have dug straight to the bottom! VPI doesn't make crap. Be prepared for lots of detailed setup, but you having a scientific mind, I think you would embrace it.
  • Joey_V
    Joey_V Posts: 8,603
    jdjohn wrote: »
    I have 2 options, buy a starter table or an endgame.
    I was looking at the Project RPM10 carbon but I have an option for the Avenger Reference with Etna, set up by John Fort. So my mind starts thinking...
    If I buy a starter table, what if it’s not significantly better than my digital? And then is it just going to cost me more in the long term?
  • tratliff
    Joey_V wrote: »
    tratliff wrote: »
    The table:
    The cartridge:
    Lyra Etna
    Phono:
    It did take some time to get use to but once it was broken in I haven’t looked back. I check all settings a couple times per year but can’t remember the last time I actually made a change.
    You will be very happy with that setup. Just keep in mind listening is more effort. And collecting records is a 🐇 hole.....
  • Joey_V
    Joey_V Posts: 8,603
    Which do you have?
  • tratliff
    Joey_V wrote: »
    Which do you have?
    I have VPI Prime with Soundsmith Zephyr MIMC and Parasound JC3. Along with a Stereo Squares plexi cover.
    I also have a Denon DP-59l with a Ortofon 2M Bronze.
  • jdjohn
    jdjohn Posts: 3,416
    Joey_V wrote: »
    No doubt business is good in the ED, so take that leap to the VPI :) You deserve it in these trying times as a health-care provider. HOWEVER, consider your little ones, and if they might attempt to...whatever.
    F1nut Posts: 52,183
    VPI tables and Soundsmith carts are a match made in heaven. Unipivot is a bit strange at first, but you catch on quickly. They now have a little plate you can attach at the pivot, which makes it steadier without any negative effects.
  • jdjohn
    jdjohn Posts: 3,416
    Jesse, have you gone full strain-gauge, or one of Peter's moving iron options?
    F1nut Posts: 52,183
    Yeah right...lol
    Zephyr MIMC Star
  • Joey_V
    Joey_V Posts: 8,603
    jdjohn wrote: »
    Joey_V wrote: »
    Ha, it’s not that good. Otherwise, I wouldn’t be ruminating about which is most bang for the buck.
    Let’s just say I’ve denied myself for long enough.
  • tratliff
    Yeah right...lol
    Zephyr MIMC Star
    Nice Jesse. What table you running?
  • jdjohn
    jdjohn Posts: 3,416
    It's a brave new world. But remember with vinyl, it is all about the accessories. Cleanliness is next to Godliness, so you'll need a RCM, brushes for vinyl and stylus, anti-static solutions, new sleeves in many cases, etc.
  • Joey_V
    Joey_V Posts: 8,603
    Yeah
    Sounds like a blackhole
  • displayname
    jdjohn wrote: »
    This is really good advice. I'm no where near the end of the pool being discussed here, but I've seen enough to know that as you bring in more resolution to vinyl, you also can bring in more need for perfection and maintenance. Not only do you need to find good masters, but they have to be good pressings. And they have to be CLEAN. As your resolution goes up, so does the magnification of every imperfection.
    You'll want to do some serious research on cleaning, set up, and maintenance before diving in. I'm actually assuming this was already factored in if you're looking at this level of gear, but it just cannot be stressed enough. Sometimes you might have to clean a record 4 or 5 times to really get it clean. Getting into vinyl is like getting into a high maintenance cars. Amazing fun if you enjoy it, but you'd better enjoy the work of it too... or have someone to do it for you.
    The mention of the kids is also relevant. Good set up and clean records will allow you to run the same stylus for a very long time. But children or a pet (usually cats) can completely destroy a cartridge in the blink of an eye.
    But even with all of its complications, I still love the vinyl side of the hobby. I actually kind of enjoy the process of cleaning a record and cataloging it. I love finding new albums at a record store. I love the way great vinyl can sound. I love the way a well set up table runs like a refined time piece. It's a hobby within the audio hobby, and it's not for everyone, but it's certainly for me.
    Discogs
    Clipdat Posts: 13,101
    Joey_V wrote: »
    Clipdat wrote: »
    Serious question
    No idea. I suggest you call VPI and ask them that question, I'm sure they would be happy to assist.
  • marvda1
    marvda1 Posts: 4,965
    Puritan PSM156
  • displayname
    SME is another legendary brand in the high end TT space, and I will point out that you see their tone arms land on other tables frequently. Herb Reichert used an SME arm on his reference TT, Steve Guttenberg uses an SME table in his reference system. Nothing like 3rd party validation of a design. Something to consider.
    Discogs
