What are the advantages to an outboard? passive crossover.
I would like to know if anyone has compared an out of the speaker box passive crossover to the same passive crossover in the speaker box?
Best Answers
  • BlueFox
    BlueFox Posts: 15,250
    Answer ✓
    Interesting question. The vibrations might be reduced, but the wiring length will be greatly increased.
    VR3 Posts: 29,533
    Answer ✓
    In my experience there is not enough gain to go external to do it without additional upgrades.
    I only go external when the parts selection requires it.
    In some instances you have to tweak values to compensate for the additional wire runs
Answers
    pitdogg2 Posts: 27,230
    edited September 2020
    Yes a couple here have. Let me reiterate, they built much better crossover with primo parts that would not fit inside. Old XO was no longer used.
    Post edited by pitdogg2 on
  • invalid
    invalid Posts: 1,519
    I was wondering if anyone had compared the difference with the same crossover inside the speaker box to a separate out of the box crossover, kinda apple's to apple's comparison. Just curious to find out if it sounded better not being in the box with all the vibrations and all.
