Vincent Pho 8 phono amp power supply
CH46E
CH46E Posts: 3,595
edited September 2020 in Troubleshooting
After some help from a av repair guy, I know that the power transformer is bad.
There is no continuity or resistance on the input/primary winding. I removed the primary from the circuit also.
Now I'm trying to figure out why the primary might have failed.
Tom Ward of Pangea Audio /Audio Advisor said he has never seen one fail in the Pho 8.
The fuse in the iec connector is good.
I removed a small cap that was on the back of the iec. I appears to test good.
The only other part between the iec, the switch and transformer is a blue polyswitch. Thats the item I dont know how to test and or even if it was bad, would it cause the primary to fail?
You can see where this thread started here. https://forum.polkaudio.com/discussion/191754/van-alstine-vision-phono-preamp-vincent-pho-8-phone-preamp
    mhardy6647 Posts: 35,050
    Does the PT have a fusible link in the primary?
    (over and above the mains fuse, that is)
    I mean, basically, an open winding - if not just a "QC" failure of a part - would indicate to me way too much current drawn by something downstream. Shorted capacitor or rectifier being the most obvious/likely culprit(s).
    Just musing, though, of course.
  • CH46E
    CH46E Posts: 3,595
    If there was a fusible link in the primary would it even be serviceable?
    CH46E wrote: »
    nope.
    Well -- let me rephrase that :)
    It wouldn't have been intended to be serviceable.
    But, to some folks -- that's a challenge!
    Transformers -- sometimes -- can be dissected.
    I had to repair one on a Radio Shack SAF-40 once. Turns out that the output transformers on those had a weak spot, but it was very close to the outside world and could thus be repaired. Just have to lay off coffee for the morning before tackling ;)
    You can probably see the discontinuity in the varnish-insulated copper wire in the photo above. :#
    ahem -- back on topic...
    My guess is that you'll need a new PT. But -- as they used to warn us in the days when stuff could be repaired -- it is folly to replace a PT prior to determining that no fault lies upstream of the transformer. Your interaction with the "Pangea Audio" person suggests that he thinks there's something goin' on upstream of the PT.
    That may be hard to troubleshoot -- although a "DBT" (dim bulb tester) might be helpful to suss it out after installing a suitable replacement PT.
    Given that the PT's specs (not current requirements, but output voltages) are given to you, it would (should!) be possible to rig up a power supply in the form of three cheap (e.g., surplus/junkbox) fixed voltage PTs and troubleshoot from the mains input without putting a 'bespoke' PT at risk. Should. ;)
    ... again, some folks take "impossible" as a challenge. :)
  • CH46E
    CH46E Posts: 3,595
    edited October 2020
    I found this photo of the inside of another Pho8 pre amp. It has what appears to be a part number but I can't find anything for a replacment.
    Does anyone else know where to search this part number??
    @ZLTFUL , I know you looked before but thought maybe this new number might help????
    ECTHF 0911.
  • CH46E
    CH46E Posts: 3,595
    I'm waiting to hear back from Pacific Transformer. They advertise "no job too small". So I asked for two of them. Not sure they will make them or not, worth a shot.
    pitdogg2 Posts: 27,075
    Tell Russ to go home....
    :p
  • invalid
    invalid Posts: 1,461
    Not to hijack this thread, but why does vincent solder the tubes into the circuit instead of using a tube socket?
  • They probably do it to eliminate a mechanical junction which because of different metals between the tube pin and the socket could cause a slight (possibly audible, who knows?) diode effect. Sure makes tube rolling a bit more challenging, eh?
  • CH46E
    CH46E Posts: 3,595
    I thought maybe it was cheaper to pay someone to solder then to buy the sockets??
    Clipdat Posts: 13,095
    At this point I'm just going to buy you a phono pre and have it drop shipped to you so you can start listening to vinyl. Life is too short lol.
    PM me your address.
    edited November 2020
    Nice dude! I like that all metal chassis! Enjoy! Looking forward to hearing about how it sounds.
    Also for the record I didn't choose to have it say a corny rhyme on the receipt.
    "A gift for you from Drew" really? REALLY? But Amazon wouldn't let me put anything less if I wanted to not have the price displayed lol :p
  • CH46E
    CH46E Posts: 3,595
    I will try to get this Pho 8 fixed and karma it off.
  • Drew, you are an exceptional person!!
    Harry / Marietta GA
  • Mam vincent pho 8 a aj tam prestal transformátor fungovať. Chyba bola priamo v nom. Zhorela tepelná poistka. Problém vyriešený.
    msg Posts: 10,452
    ^^^ nice job, and good info.
