SDA's Back In The House!
Picked up a pair of 2b's this weekend. Cosmetically in pretty good shape. Supposedly the original owner. SL 2000 tweeters, oak tops and bottoms. Has the original interconnect. Have not opened them up yet, but I am pretty sure they are stock. They will be my winter project, or one of my projects. The side panels have come loose. What is the best adhesive to
re-attach them? Power Grab, Liquid Nails or?? Also the cloth on the panels needs to be re-glued in a couple of places. Best glue for that? I will post pics in the next couple of days.
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
Main speakers are still the Zu Dirty Weekends, but I want to mess with these for a few months and see what happens. Listened to the Zu's coupled to 300b monoblocks today and the 2b's hooked to the Rogue Cronus Magnum. Really a different sound between the two. Of course the 2's probably need a recap, but the detail with the Zu's is incredible compared to the 2's. The 2's have a much bigger soundstage. We will see.
And are you still liking the little Dared pre Ivan? The Dared was my first dip into tubes. Since then I have fallen down the rabbit hole. Been holding on to the sides to slow things down. Been doing pretty good......... until this last Saturday. But, I did get the grass cut today. Right around 2 1/2 hours. Done before noon and had a martini lunch with a friend.
$550. Completely redone, including beautiful cherry veneer. In my opinion a real bargain.
The Dared yes I like it but looking for another tubed pre Bruce.
I remember them. The best looking 12s I've seen for sure.
I am currently using an Aric Audio pre. Pretty happy with it. Those are a good deal if you can find one used. They don't come up very often. Check out his website.
