Has anyone suspended a sub?
CH46E
CH46E Posts: 3,521
My floor space in tight but I have 10ft ceilings. Has anyone lifted or suspend one off the ground? Maybe closer to the cealing than the floor????
    audioluvr Posts: 5,420
    I've seen them in walls, ceilings and employed into coffee tables but never suspended
  • CH46E
    CH46E Posts: 3,521
    edited August 2020
    I'm looking at a Stereo Integrity 15. So in-wall is out of the question. Lol. As far as ceiling goes it gets to 150 degrees up there in the summer. Id hate to subject it to that heat.
    Can't be any worse than the trunk of a black Honda Accord...
  • I've hung lots of subs in churches and auditoriums. Most used 3 point suspension to control tilt and minimize sway. The most important thing is safety, use heavy duty bolts with lock washers, and nuts. Never trust lag screws when overhead.
    Clipdat Posts: 12,560
    audioluvr wrote: »
    Hopefully it sounds better than that though.
  • joecoulson
    joecoulson Posts: 4,943
    Would the whole thing sway with the excursion?
  • CH46E
    CH46E Posts: 3,521
    joecoulson wrote: »
    I was kind of worried about that. I could put a single static brace to prevent that. I also thought opposing drivers might work, but that puts me into a cost and location difficulty I don't want.
  • afterburnt
    afterburnt Posts: 7,892
    I have my two-channel subs sitting on top of my HT subs
  • halo71
    halo71 Posts: 4,567
    I've never suspended one before. But I've expelled a few over the years.
    --Gary--
  • joecoulson
    CH46E wrote: »
    joecoulson wrote: »
    I would think that brace would be the point of contention and either hurt the performance or overly exacerbate vibrations.
  • Gardenstater
    Gardenstater Posts: 4,136
    edited September 2020
    I think the 3 chains idea is good, and I would add some 9 in. long extension springs between the chain and the sub for vibration isolation, in which case I'd use 4 chains and 4 springs. I believe the static brace is a good idea a la Matthew Polk's Bass Brace and I would put a sorbothane or isodamp (or the like) bumper on it where it contacts the sub.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Dennis Gardner
    Dennis Gardner Posts: 4,860
    Here is a pic of the last subs that I hung in a small town gym. They were dual 12” in each cab band pass models. Used to give a little bass bump to halftime music at the games. houspvzb63du.jpeg
    Use aircraft cabling for strength and invisibility. I painted cabling and all hangers black if the speakers were black against black ceilings.
  • afterburnt
    The only thing I would be concerned with equal and opposite movement muddying things up.
  • afterburnt
    Also do you have some James Bond like suction cups to do the sub crawl?
  • CH46E
    CH46E Posts: 3,521
    these are all great questions in response to mine. Maybe its not worth exploring this as an option. To many variables and like afterburner said, how am I gonna sub crawl that for placment?
